One headlight out...
Old Oct 7, 2006 | 11:25 AM
ghost SHell's Avatar
Default One headlight out...
So my passenger headlight (lowbeam) is out. I tried replacing the bulb thinking it was a dead bulb. However the original light is fine and the new bulb doesn't work either. I switched the fuses and that didn't work either. Anyone know the problem? The High beam works just fine as well as the small parking light.
Old Oct 8, 2006 | 10:31 AM
Default Re: One headlight out... (ghost SHell)
bump please...
Old Oct 8, 2006 | 10:34 AM
ghonaherpalitis's Avatar
Sounds like a bad connection. Check your writing with a volt meter
Old Oct 8, 2006 | 10:49 AM
Duane_in_Japan's Avatar
Default Re: (ghonnaherpalitis)
Checking for power is first, using a wire diagram is next working your way back to the light switch, take it out and look for the burnt spot, then change it if needed.
Old Oct 8, 2006 | 10:50 AM
94Vtecluder's Avatar
Default Re: (Duane_in_Japan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">Checking for power is first, using a wire diagram is next working your way back to the light switch, take it out and look for the burnt spot, then change it if needed.</TD></TR></TABLE>
Old Oct 8, 2006 | 11:02 AM
GraphiteMW's Avatar
Default Re: (94Vtecluder)
Where could I find a wiring diagram at?
Old Oct 8, 2006 | 08:59 PM
Default Re: (GraphiteMW)
Library, Motor or Chiltons manual or even Haynes, good luck.
Old Nov 14, 2006 | 04:27 PM
cfran55's Avatar
i also need help my jdm driver side headlight low beam is out i switched the bulb to the passenger side and it works i checked the fuses they were fine. What could it be the h1 harness(i think its from a civic)? i will switch the passenger and drivers side tomorrow and see if that works.
Old Nov 15, 2006 | 04:57 AM
cfran55's Avatar
Default Re: (CFran55)
bump!
ed2
Jun 8, 2010 11:09 PM
Kendo88
Oct 25, 2008 11:33 PM
Colby71
13
Dec 31, 2006 03:40 PM
OMG naD16 lol
Dec 13, 2006 09:19 AM
integraracing91
Dec 3, 2006 03:43 PM
