ok very quick question about offset
Old Mar 24, 2008 | 04:33 PM
94vtirozguy's Avatar
Default ok very quick question about offset [searched]
ok guys i have access to some rays gram lights.
they are 16*7 with +42mm offset. this is for a 4th gen lude.
will i have any issues with tyres rubbing if the car is lowered ?
also what is the stock wheel offset for the 15 * 6.5's ?
Modified by 94vtirozguy at 11:58 AM 3/25/2008
Old Mar 24, 2008 | 06:22 PM
ok found out the following so far:
S model + 50 offset (F22 series)
SI model + 55 offset (H23 series)
VTIR or si_4ws + ?? (H22 Series)
Old Mar 25, 2008 | 12:14 AM
95greenlude's Avatar
Default Re: (94vtirozguy)
depends on the tire size, but generally you should be fine....
Old Mar 25, 2008 | 09:03 PM
thanks.... was planning on sticking with a 205 or 215.
Old Mar 26, 2008 | 02:03 PM
my9thtry's Avatar
225/45/16 is almost exactly the same size as stock(within 1%) , and you shouldnt have any rubbing issues depending on how much your lowered.
Old Mar 26, 2008 | 02:06 PM
Danny BAGDAD's Avatar
yeah, you should be good
Old Mar 26, 2008 | 02:51 PM
Default Re: (my9thtry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my9thtry &raquo;</TD></TR><TR><TD CLASS="quote">225/45/16 is almost exactly the same size as stock(within 1%) , and you shouldnt have any rubbing issues depending on how much your lowered.</TD></TR></TABLE>
225 you will have a VERY high chance of rubbing while being lowered...... go with some 205's
i'm running 205/45/16
Old Mar 26, 2008 | 06:17 PM
my9thtry's Avatar
Default Re: (95greenlude)
i run 225s im dropped on Pro kits springs / Konis. No rubbing at all, everyone isnt as low as you Mr green lude . thats also why i said depends on how low you go
Old Mar 26, 2008 | 11:05 PM
snobordboy's Avatar
Moderator
Yeah unless you are slammmed to the ground like greenlude or myself, you will be fine, even with the 225/45. I run 205/45/16 and get a small rub when turning the wheel when backing up. Oh and I believe my wheels are 16x7 and +43 offset.
Old Mar 26, 2008 | 11:17 PM
Default Re: (snobordboi)
^psh your not low!
i'm waiting to get some cash so i can throw some 15mm spacers up front.....+35 ftw
Old Mar 26, 2008 | 11:30 PM
snobordboy's Avatar
Moderator
haha yeah I am as low as I would dare go, so you can keep that extra .2 inch that you have on me! And I am debating a 5 lug swap and redrilling my volks from my wrx to run 17x7.5 with 225/45/17s, but Id have to go up a bit then.
Old Mar 26, 2008 | 11:35 PM
^ i'm just giving you a hard time....as of now i am no longer "slammed"....i have about a fingers gap in between each fender
Old Mar 26, 2008 | 11:37 PM
snobordboy's Avatar
Moderator
Haha yeah I figured, mines still low since it sits in the garage all winter, and at least another 3-5 weeks till my broken ankle and leg heal so I can use a clutch again, or walk for that matter.
Old Aug 11, 2008 | 06:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my9thtry &raquo;</TD></TR><TR><TD CLASS="quote">i run 225s im dropped on Pro kits springs / Konis. No rubbing at all, everyone isnt as low as you Mr green lude . thats also why i said depends on how low you go</TD></TR></TABLE>
just revisiting this.. you have same suspension setup as i have and i can;t find 215 in 16's... its either 205 or 225.
Leaning towards the 225 45 16
Old Aug 11, 2008 | 06:34 PM
Kronn 98SH's Avatar
215/45/16 - 0.3" smaller diameter than stock
http://www.tirerack.com/tires/...0&y=8
225/45/16 - same diameter as stock
http://www.tirerack.com/tires/...&y=14
g3teg97
Apr 17, 2008 06:42 AM
yaryar
Jan 10, 2008 07:11 AM
jsk62
Apr 20, 2005 05:14 AM
PotatoePAPA
Apr 19, 2003 02:06 AM
nEoMuGen
Jan 16, 2002 07:07 PM
