Oil ?
Old Oct 13, 2007 | 03:18 PM
Tip14's Avatar
Default Oil ?
I have a quick ? If my car is buring oil can I put in a heavier weight oil to my stop the buring from being as bad. Ive been runnin 5/30 scine I got it and that was at 150000 it has 162000 on it now also the previous owner ran 5/30 as well Im not sure on what brand.
Old Oct 13, 2007 | 04:25 PM
alexisthemovie's Avatar
you can run thicker oil as a band aid. 10w40 would be a good step up. you can also try engine restore in a can. that **** works pretty well and i'm speaking with experience.
Old Oct 13, 2007 | 04:48 PM
Fei8Lo's Avatar
Default Re: (alexisthemovie)
i put a can or restore in to see if it does any thing. also i got a filter mag to pull alot of the metal particles out of the oil, that way maybe i would help with the engine wear, and maybe the restore stuff can work longer with out having to use it every oil change.
Also i used some lucas oil stablizer in some other cars and it slowed the oil usage alot, there is alot of crap saying its not good, but it does slow oil consumption.
Old Oct 13, 2007 | 05:00 PM
Default Re: (Fei8Lo)
i read mostly good reviews, some neutral, and very few bad reviews but those people probably had a huge problem to begin with.
i decided to try it myself and have to say the results are great!
Old Oct 13, 2007 | 06:03 PM
98vtec's Avatar
moderator emeritus
http://www.bobistheoilguy.com
Old Oct 13, 2007 | 08:07 PM
Tip14's Avatar
Those are some good answers but is there any additive that is proven to help stop or reduce buring oil that someone on here has used before
Old Oct 14, 2007 | 10:14 AM
Tip14's Avatar
Bump
Old Oct 14, 2007 | 12:23 PM
engine restore in a can as i mentioned.
Old Oct 14, 2007 | 01:10 PM
mattsnooz's Avatar
x2
I recommend Lucas oil stabilizer as well!
FitsMe
Honda Fit
Apr 16, 2012 05:05 AM
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
redLUDEs2k1
Oct 12, 2005 10:21 AM
ironballz
May 13, 2004 02:38 PM
jonnyR
Jul 30, 2001 11:33 PM
