OBDI Conversion
Old Nov 10, 2002 | 02:31 PM
blacklude's Avatar
Default OBDI Conversion
I keep hearing about OBDII to OBDI conversiosn and had a few questions.
Is the conversion worth it? Are there any mods which should be done first? Will it matter if I'm going to get a V-AFC? What is needed to do the conversion?
I know that's a lot of questions, thanks for the help.
Old Nov 10, 2002 | 02:43 PM
BigChris's Avatar
Default Re: OBDI Conversion (blacklude)
I would definetely suggest converting to an OBD I. It has less restrictions on it. If you were to do the wiring yourself, it would be a PAIN in the ***. Skunk2 makes an OBDII to OBDI conversion kit. If you goto their website http://www.skunk2.com and click on Electronics and then Conversion Harness you will see it there. Hope this helped you with the OBD conversion
Old Nov 10, 2002 | 03:12 PM
satan_srv's Avatar
Default Re: OBDI Conversion (BigChris)
You need:
Conversion Harness
OBDI ECU
You can redo the wiring yourself if you know what you're doing. You just need some OBDI plugs you can scam at a junk yard.
Old Nov 10, 2002 | 03:18 PM
blacklude's Avatar
Default Re: OBDI Conversion (satan_srv)
Where can I get an OBDI ecu?
Old Nov 10, 2002 | 03:29 PM
BigChris's Avatar
you can find an OBD I ecu at a local junkyard or you can even check to see if there any on ebay.
Old Nov 10, 2002 | 05:33 PM
Sticky Tires's Avatar
* B A N N E D *
what are the difference from a OBDI I and OBDI II? i read that it disables the immobilizer, would it also wouldnt work with ATTS?
Old Nov 10, 2002 | 05:52 PM
dka's Avatar
dka
i would do the obdII workaround instead. If you want to go obd1 and are serious about performance, might as well just go with a complete EMS.
Old Nov 10, 2002 | 05:55 PM
blacklude's Avatar
Default Re: OBDI Conversion (dka)
What's the OBDII workaround?
Old Nov 10, 2002 | 05:56 PM
satan_srv's Avatar
serenity now!!!
http://www.ntpog.org/mods/fifth-afc/ecu.shtml
EvasiveMotorsports.com
Performance
17
Oct 30, 2009 02:51 PM
Happy Gilmore
Jun 12, 2008 05:33 AM
All Day
Mar 8, 2006 06:11 AM
RACEPAK
Feb 13, 2005 03:09 PM
93slmdcvcsi
Aug 6, 2004 08:32 AM
