O ring leak
Old Dec 21, 2007 | 01:59 PM
Tip14's Avatar
Default O ring leak
Hey guys my distubtor o ring is leaking and the car is losing about a quart of oil for every 1 half hours I drive. Does the o ring leak that much oil or is it something else. I have searched up and down the motor and I cant find anything else. What are some common things that usally leak at 164000.
Old Dec 21, 2007 | 02:14 PM
Acidcrakker's Avatar
Default Re: O ring leak (Tip14)
Just about anything and everything can leak. Your best bet is to degrease the WHOLE engine, replace that O-Ring and go from there.
Old Dec 21, 2007 | 02:17 PM
waynecoSI's Avatar
Default Re: O ring leak (Acidcrakker)
yea just do what Acidcrakker said and keep an eye on it.
Old Dec 21, 2007 | 02:27 PM
Tip14's Avatar
So lossing an a quart of oil is common with an o ring leak? I have been trying to find out what has been eating up my oil for a long time hopefully this is it.
Old Dec 21, 2007 | 02:38 PM
Default Re: (Tip14)
probally not, what you need to do, is what I said above. That will eliminate one problem right away, clean off the engine, and you will have very little problem noticing the leak.
Old Dec 21, 2007 | 09:13 PM
dagle's Avatar
Default Re: (Acidcrakker)
i have the same dizzy o-ring leak, i leak a few drops per day. just lazy since its winterbreak, but im taking the car in for electrical repairs at a general repair shop and just having them do it. ill guess that its not supposed to lose that much though, when you check your oil is the car cooled down?
i mean it sounds stupid but it could just be oil working its way back to the bottom that you're taking as missing oil.
Old Dec 22, 2007 | 08:35 AM
vlang29's Avatar
if the o-ring is bad enough that it split, it could easily leak that much. When my oil cooler o-ring went, my oil light came on, i refilled it to full, and within 4 miles the oil light was on again... took me 10 quarts to make it 10 miles home.
Old Dec 22, 2007 | 01:17 PM
Tip14's Avatar
I replaced it today but it still leaks a little bit Im going to take another crack at it tomorrow. I had to force it back into the slot I think the o ring I got is to thick lol
F!ip
39
Feb 7, 2011 12:21 PM
Lithel
May 5, 2008 06:46 AM
98prelude1
Jan 29, 2008 05:56 AM
