no start problem.....
Old Jul 30, 2009 | 06:48 PM
mr_fobster's Avatar
Default no start problem.....
well i just did a intake mani gasket on my homies 94 prelude si, and no it wont start....im getting no fuel and i do no hear the relay click or the pump priming. i checked fuses and there all good, so would you guys suggest doing a main relay?
its just the weird thing about this is that it was starting fine before i did the gaskets, and the only electrical plugs i took off were the iacv, fast idle valve, tps, dual runner sensor.
any suggestions?
Old Jul 30, 2009 | 09:02 PM
Matgallis's Avatar
Default Re: no start problem.....
did you plug your injectors back in?
Old Jul 30, 2009 | 09:12 PM
maz69's Avatar
allmost the exact same thing happened to me and it turned out to be a ground down by the thermostat
Old Jul 31, 2009 | 08:32 AM
mr_fobster's Avatar
yea ill check that ground now...it night be that. and i didnt un plug the injectors...i just took off the fuel line and poped the fuel rail off and moved it to the side.....
Old Aug 6, 2009 | 07:14 PM
h2b eg's Avatar
yeh i would check the ground by the thermostat i did that before swapping engines pissed me off
si_motor_spt
Aug 17, 2022 10:52 AM
95PreludeNAed
Jan 10, 2012 04:09 PM
OMG WTF
Feb 14, 2009 12:13 AM
dk127
Nov 6, 2008 02:33 AM
MADEinJAPAN
Sep 27, 2003 09:36 PM
