need some help asap
Old Feb 9, 2006 | 04:35 PM
coreyfrenzel's Avatar
Default need some help asap
i have a 92 lude si h23 and i blew the balance shaft seal and replaced that along with installing the retainer and since i was done there i changed the t belts now the car runs like *** any help would be awsome. thanks
Old Feb 9, 2006 | 04:42 PM
DJ_SaNdOz's Avatar
Default Re: need some help asap (coreyfrenzel)
Is the timing correct?
Old Feb 9, 2006 | 04:43 PM
93h22a1vtec's Avatar
Default Re: need some help asap (DJ_SaNdOz)
ur prolly off a tooth
Old Feb 9, 2006 | 04:46 PM
i am pretty sure its dead on the only one i think might or could be off is the front b shaft. i couldnt quite see up in there to see if it was on the mark. what else could it be this is my only car right now and i need it fixed asap thank you
Old Feb 9, 2006 | 04:54 PM
another question why is it when i put a rod in the cams that the belt doesnt fit on too great? there is slack beween the cams.
Old Feb 9, 2006 | 05:13 PM
Default Re: (coreyfrenzel)
there is prolly slack cause u are off a tooth, or cause u didnt get the slack out properly, turn the motor over a little, see if the slack changes, then goes away as u turn it over by hand. and ur balance belt teeth woulnt cause it to run like ****, as a matter of fact u should just cut that belt off (2whp )
peggytheteggy
May 17, 2012 11:47 AM
hotcivicsi
10
Mar 22, 2009 10:22 AM
95civicSirCoupe
Aug 27, 2006 09:07 AM
Tony_EM1
16
Nov 11, 2005 02:58 PM
flip1199
Apr 4, 2005 08:57 AM
