Need Help From a pro
Old Jul 2, 2005 | 09:00 PM
raidencw's Avatar
Default Need Help From a pro
can i get someone tell me what you think this might be:
i have a 1993 honda prelude si 4ws with 176,000 miles. i'm running 20/50 long life oil. the 4ws light comes on sometimes. the car shuts off on me while i'm driving. i had it towed a month ago for the same problem and when it got to the shop. its started right up. 2 days ago i was driving home from school and it shut off again. i was waiting 4 hours for a tow truck and it finally started. can anyone help.
Old Jul 3, 2005 | 01:08 AM
eMpAtHy's Avatar
Default Re: Need Help From a pro (raidencw)
20/50 is way too thick of an oil..i highly doubt you would need it unless you are driving like 120+ degree weather. 10w30 should suffice.
Old Jul 3, 2005 | 05:39 AM
specialedition's Avatar
Default Re: Need Help From a pro (eMpAtHy)
older hondas i.e. the early to mid 90s accord and prelude can develop a main relay problem which is under the dash close to the fuse box when it gets hot enough there can be a short develop where the car will not start and then when it cools off or the ambient temp drops you are then able to start the car. I have seen numerous write ups on how to correct it on various honda websites do a search and you should find what you are looking for.. sounds like the main relay or a short....
Old Jul 3, 2005 | 05:59 AM
britishlude's Avatar
Also have a look at a possible faulty ignition switch, if it breaks the circuit whilst driving that can cause your 4ws light and consequent cut out. Try a light squirt of wd 40 into the switch while the key is in that can help.
clifftbrd
Jul 11, 2014 01:40 PM
prelude_girl
Classic Hondas
10
Oct 28, 2013 06:14 PM
Hotaru
Apr 23, 2012 02:18 AM
Whaty
Sep 26, 2008 08:29 PM
deviousz
Aug 21, 2002 09:41 AM
