Need Help badly
Old Dec 4, 2006 | 04:02 PM
BlueLude 94's Avatar
Default Need Help badly
I posted on here a couple weeks ago about my car and thought that it might have been hydro locked. I have worked on it a couple of times sence then to try and fix it. I have already changed the oil and still no luck. There was no water in the oil or anything. So the next thing i did was pulled the old plugs out and put new ones in. After this it began to atleast try and turn over but still wouldnt. At this point when i was trying to turn over it sounded like it was trying but it also felt like it was jumping a little bit. I also check the ditributor cap and nothing was wrong with it. What else could i try to do I really need to get this car fixed and sold hopefully before christmas.
Old Dec 4, 2006 | 04:03 PM
GraphiteMW's Avatar
Check/change out your spark plug wires.
Old Dec 4, 2006 | 04:09 PM
l2yanE's Avatar
Default Re: (GraphiteMW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteMW &raquo;</TD></TR><TR><TD CLASS="quote">Check/change out your spark plug wires.</TD></TR></TABLE>
and why in the world do you say that?
try cranking the car with no plugs in it, check for fire, check for fuel, check compression, check timing check all the basics, lets us know what you find, we will help you from there-
Old Dec 4, 2006 | 04:10 PM
Oh yeah I forgot to mention this before but as of now it doesnt even attempt to turn over. I will check to see if its the wires. My dad thinks that its an electrical problem so what are some other things to check besides fuses?
Old Dec 4, 2006 | 04:53 PM
mgags7's Avatar
lol yea I think its an electrical problem....haha
is it a manual?
Old Dec 4, 2006 | 05:20 PM
jdmh22a1's Avatar
check firing order...or even distribitor..
Old Dec 4, 2006 | 05:40 PM
Default Re: (jdmh22a1)
Yes its a Manual.
Old Dec 5, 2006 | 01:12 AM
numark34's Avatar
Default Re: (BlueLude 94)
look if you can push star it then look for an electrical problem in the starter to alternater circuit you might just need a new starter or a new alternator maybe a battery if you cant push start it drop the oil pan and check the crank bearings they might have spun and seized and if you give up how much $$$$$
Old Dec 5, 2006 | 02:43 PM
Default Re: (numark34)
Could it be the starter? because now its just makeing one click and thats it
Modified by BlueLude 94 at 4:05 PM 12/5/2006
Old Dec 10, 2006 | 08:12 AM
motman's Avatar
check the cam belt sounds like its jumped a tooth or stripped some teeth
Old Dec 10, 2006 | 11:05 AM
preludeguy_92's Avatar
Default Re: (motman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numark34 &raquo;</TD></TR><TR><TD CLASS="quote">look if you can push star it then look for an electrical problem in the starter to alternater circuit you might just need a new starter or a new alternator maybe a battery if you cant push start it drop the oil pan and check the crank bearings they might have spun and seized and if you give up how much $$$$$</TD></TR></TABLE>
x2
Old Dec 11, 2006 | 11:14 AM
jdmh22a1's Avatar
r all ur grounds in the right place??
Old Dec 11, 2006 | 11:29 AM
ninja 6's Avatar
It's the attack of the electrical gremlins. Blitz style.
Nate10-1992
Aug 5, 2008 12:09 PM
new2vtec
11
Jun 27, 2007 12:44 PM
dAilyDrIver5
19
Jun 4, 2007 05:15 PM
ek4ferrio
Jun 3, 2007 02:59 PM
typeeg
15
Jun 20, 2004 09:20 PM
