need advice on performance upgrade....
Old Dec 2, 2005 | 11:56 AM
crix868's Avatar
Default need advice on performance upgrade....
i jus installed a h22 in my integra not too long ago and was wonderin i would like to hit close to 300whp or + if anything all motor and wanted to know if i did the skunk2 complete valvetrain upgrade with camgears and camshafts with a ported manifold and a chip an tuned ecu on the dyno wha do you think my power output would be b/c i know the H22 got potential and wanna go all motor on it also if i do this would i need to do anything else or would this setup be fine for a daily driver
Old Dec 2, 2005 | 12:27 PM
AndyD's Avatar
Default Re: need advice on performance upgrade.... (crix868)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crix868 &raquo;</TD></TR><TR><TD CLASS="quote">i jus installed a h22 in my integra not too long ago and was wonderin i would like to hit close to 300whp or + if anything all motor and wanted to know if i did the skunk2 complete valvetrain upgrade with camgears and camshafts with a ported manifold and a chip an tuned ecu on the dyno wha do you think my power output would be b/c i know the H22 got potential and wanna go all motor on it also if i do this would i need to do anything else or would this setup be fine for a daily driver</TD></TR></TABLE>
You should've built the H22 before you put it in.
300whp is too high for a N/A H22.
Old Dec 2, 2005 | 12:35 PM
1GPlusSH's Avatar
Wow. 300whp n/a h22....I would love that motor. I was hoping for about 225whp for my setup, but I'm not going TOO aggressive.
I saw a 275whp h22. He told me he spent about $20,000 on that motor. Good luck to you.
Compression is going to be your friend....
Old Dec 2, 2005 | 12:36 PM
RemerLex11's Avatar
Default Re: need advice on performance upgrade.... (AndyD)
trying 300whp on a NA H22 is possible but will swallow up your money. go turbo if you want this much power
ef92b
Sep 24, 2013 08:23 AM
96accordexproject
Feb 9, 2008 07:23 AM
civicsi0721
May 6, 2007 03:19 PM
NirVTEC
May 19, 2006 01:28 PM
