Need Advice
Well its been couple of years now i haven't started on my prelude 1992 f22a6 the engine blew up my concern is i want to get this car running back again i still have wire harness transmission ive been searching and searching and ive been leaning on a f22 b dohc with p39 ecu my main concern is will there be any problems with this swap or should i just try look for a h23a1 can u guys route me to the right direction thank u so much
Re: Need Advice
Most people just go to the H22 swap, but you might find an H23 cheaper. Not sure if you will need to change exhaust manifold if you go that route, but it would need a P14 ecu as well.
Re: Need Advice
found a h22a for 900 called some local import shop in oc and they wanted 600 for the f22b dohc as i seen the h22 comes with more hp
Re: Need Advice
Remember that you have to rebuild the swap engine also
Re: Need Advice
Originally Posted by TimiK
(Post 51777599)
Re: Need Advice
Don't think you HAVE to rebuild the motor. Just test everything and swap it in. Ran a used h22 from hmo for a few years and just did the basic gaskets and timing belt before putting it in. Only pulled it out for a project.
Re: Need Advice
Originally Posted by PreludeJunkie91
(Post 51793866)
Re: Need Advice
(Post 51793991)
You HAVE to new all the seals and gaskets and while youre there its wise to do the timing and clutch jobs so basicly its rebuild
Re: Need Advice
(Post 51794138)
You tell some to rebuild and its pistons,rings, rods, bearings, head work.
