name that part
Old Jun 6, 2011 | 02:14 PM
samson_420's Avatar
Default name that part
What are these? Look kinda like vacuum actuators but from what I understand one of these might be a map sensor.
The car is 92 that came with a f22a.
Old Jun 6, 2011 | 02:28 PM
Hawkze_2.3's Avatar
Default Re: name that part
First pic is emissions stuff, last pic is a ground. I forget exactly what the 2nd pic is...
Old Jun 6, 2011 | 03:38 PM
samson_420's Avatar
Cool. . . . So where is or was the map sensor?
Old Jun 6, 2011 | 03:46 PM
Hawkze_2.3's Avatar
Either mounted on the throttle body or the firewall right behind the throttle body.
The one on the right in the 1st pic might be the MAP sensor, just can't tell for sure from the pic.
Old Jun 6, 2011 | 07:46 PM
nemesis25's Avatar
Pic 1 = Map sensor, and it actually says so on the sensor.
Pic 2 = Egr control device.
pic 3 = Ground cluster.
Old Jun 6, 2011 | 08:20 PM
samson_420's Avatar
U r the man
Old Jun 7, 2011 | 05:47 AM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
The bit on the right in the first pic is the purge solenoid for the carbon collector can. I remember taking mine out..
Old Jun 7, 2011 | 06:08 AM
oranginal's Avatar
Originally Posted by Hawkze_2.3
....last pic is a ground...
Good to know if you plan on a wire tuck as this will cause your fan to run slow and lead to overheating issues.
Old Jun 7, 2011 | 08:54 AM
samson_420's Avatar
Here is one more. It looks like some sort of PTO. It's on the tranny, but it also seems like a pump. But it hooks to the power steering pump.
Old Jun 7, 2011 | 09:01 AM
Hawkze_2.3's Avatar
VSS (vehicle speed sensor)
Old Jun 7, 2011 | 09:37 AM
samson_420's Avatar
Huh. . . . Why are there liquid lines going to it? Plus there is another sensor on top of the tranny.
Old Jun 7, 2011 | 09:38 AM
Hawkze_2.3's Avatar
It's a speed sensitive power steering system. You said yourself it goes back to the power steering pump
Old Jun 7, 2011 | 09:41 AM
Hawkze_2.3's Avatar
This site may help you: http://www.hondaautomotiveparts.com/
They provide parts diagrams for every part on the cart as well as a name and part number
Old Jun 7, 2011 | 05:37 PM
TheJGB3's Avatar
The part in the 2nd pic on the right is the VALVE ASSY., FREQUENCY SOLENOID (#2 below). It controls the amount of vacuum applied to the EGR valve .
Old Jun 7, 2011 | 06:03 PM
samson_420's Avatar
Cool and cool
FastAsleep
Aug 20, 2006 02:46 PM
damn_import_culture
May 10, 2006 07:12 AM
spoonJDMteg
Nov 9, 2003 07:18 PM
vti-R
Feb 7, 2003 08:57 PM
CivicHB_92
Jan 22, 2003 11:54 AM
