My compression fixed itself?
what do you guys make of this?
about 2 years ago i compression tested my car. my 4th cylinder had bad compression, my numbers were like 205 208 202 168. this pissed me off but whatever, the car still felt strong.
i then compression tested it after a year of spraying and came up with just about the exact same numbers, with the bad 4th cylinder. i did the second compression test with a different tester, and actually in an engine class i was taking at the time so there is no question about if i was doing it right or not.
Anyway, today we compression tested my friend's prelude, and i didn't really want to even see what my numbers were but we did mine after his anyway. i came up with just about perfect 215's all the way across. i redid it three times to make sure, and i keep getting the same results! so obviously i am happy, but how is this possible? could a piston ring have re-settled or something?
It is possible that your valve was not sealing all the waybecause of carbon and the nitrous got it hotter then normal and burned it out.
I have heard that before. Sounds like a long shot but?
builtprelude
Jan 22, 2004 10:49 PM
