map sensor on a 4th gen lude
I have a 96 lude, which obviously is obd2, and the map sensor is on top of the TB correct? So where would it be on a, say 95 lude (obd1)?
The reason why im asking is because i swapped in a jdm h22 and there is no plug on top of the TB, so do i just leave it hangin or do I have to do some kind of wiring or something. Oh yeah, i am still using the obd2 harness.
The Map sensor is on a small bracket right behind the intake manifold on the firewall. Pre-obdII. (My Car)
Where is your original throttle body from the '96 lude? Why do you have to get a hold of one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec96Lude »</TD></TR><TR><TD CLASS="quote">so would re-wiring be in order unless i was able to get ahold of a obd2 TB?</TD></TR></TABLE>
no. there shouldnt be any rewiring involved. Just use your obd2 Map sensor and run a vacuum line from your obd2 map sensor into the jdm throttle vacuum nipple. That should be it.
ahhh gotchya. You could just swap out TB's though to couldnt ya? That way the plug is right there and the harness would just plug right in.
There is one other piece i had a question on. There's this little stubby piece that comes out from the block right under the dizzy that the radiator hose connects to, now on obd2 there is a plug for the harness to connect to but on the jdm engine there is no plug there. Can you just leave that one unplugged? What is that one for, just emmissions crap?
