LSD
Old May 30, 2005 | 08:06 PM
IIVIIoOkY's Avatar
Default LSD
im lookin to get an LSD. i wanted to know if anyone knew any specifics on what i should look for like brand wise and stuff like that...
thx
Old May 30, 2005 | 08:16 PM
VSBB6's Avatar
Default Re: LSD (xLude97)
Im happy with my Quaife.
Old May 30, 2005 | 08:17 PM
john d
Guest
Posts: n/a
Default Re: LSD (VSBB6)
oem or quaife, depending on how much power your gunna put down
Old May 30, 2005 | 09:04 PM
AccordRacing's Avatar
Note that theyr two types of ways they make LSDs .. one is with plates, and the other is gears .. OEM & Quaife both use gear LSDs .. I think most other companys (KAAZ, Cusco, Ect ..) use plates / discs .. I personally think the gear set-up would be better ..
Old May 30, 2005 | 09:07 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: LSD (john d)
quaife some thing like kaaz works better but it needs mantinece one like phantom just sucks *** and i heard the obx one sucks too
dimes_prelude's Avatar
go with phantomgrip http://www.phantomgrip.com/pro...Honda
Old May 30, 2005 | 09:39 PM
bad-monkey's Avatar
Default Re: LSD (dimes_prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dimes_prelude &raquo;</TD></TR><TR><TD CLASS="quote">go with phantomgrip http://www.phantomgrip.com/pro...Honda</TD></TR></TABLE>
more like phantom ****...
stick with quaife.
Old May 30, 2005 | 09:41 PM
Default Re: LSD (bad-monkey)
why dont you like phantomgrip
Old May 30, 2005 | 09:52 PM
IIVIIoOkY's Avatar
obviously since i made this post im not sure on most things but since ive searched for some stuff i havn't really seen anything bad about phantom. maybe he doesn't like it cuz its cheaper or something but really id rather have the more reliable part so ima need to look further into it...
raylude's Avatar
lol
Old May 30, 2005 | 09:53 PM
IIVIIoOkY's Avatar
Default Re: LSD (raylude)
hey if im gunna do this i wanna do it right lol give me sources and stuff
Old May 30, 2005 | 09:57 PM
raylude's Avatar
listen to monkey he knows his ****
Old May 30, 2005 | 11:49 PM
budget's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xLude97 &raquo;</TD></TR><TR><TD CLASS="quote">obviously since i made this post im not sure on most things but since ive searched for some stuff i havn't really seen anything bad about phantom. maybe he doesn't like it cuz its cheaper or something but really id rather have the more reliable part so ima need to look further into it...</TD></TR></TABLE>
search before you post then
Old May 31, 2005 | 12:37 AM
eMpAtHy's Avatar
Default Re: LSD (Straight Flush)
the m2b4 tranny if ur tranny is shitting out on you.
Old May 31, 2005 | 04:05 AM
KENLUDE97's Avatar
Default Re: LSD (eMpAtHy)
the phantom grip Theory is to only work in a straight line. If you are building a strip car then the Theory would work with a "phantom slip"
Stick with a Quaife or Kazz or OEM. i have a OEM and it has done really well for me. I'm basically stock as far as power adders go. I do run the car pretty had for Auto-x. and it seams to respond very well.
Good luck and spend the $ for the good equipment. you will NEVER be dissapointed.
I have drove a Phanton slip car and it was VERY unpredictable when and where it decided to work.
Good luck
Ken
Old May 31, 2005 | 08:11 AM
bad-monkey's Avatar
Default Re: LSD (KENLUDE97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENLUDE97 &raquo;</TD></TR><TR><TD CLASS="quote"> the phantom grip Theory is to only work in a straight line. If you are building a strip car then the Theory would work with a "phantom slip"
Good luck
Ken
the theory of a phantom grip is to bind the spider gears in the tranny with a spring and some metal plates. apparently it works when OPM makes the diff for B and D series trannies, but phantom grip's version is either shoddily made, designed differently, or both. it's a piece of ****. it works consistently for a short period of time before it starts randomly deciding when it wants to work and when it doesn't. if you like tearing down your transmission to replace phantom grip units every few months, please buy one. otherwise, save yourself the time and the headache and get yourself a quaife.
it may cost double what a PG does, but once it's in it'll always work. probably longer than you own the car.
a Kaaz will "work" better in that you'll get more affirmative LSD engagement out of it, but since it's a clutch type it requires more maintenance: a special MTF and periodic teardowns to replace the clutchpacks.
if you want to go the OEM route, you have to buy a whole new tranny, specifically the m2b4 tranny, which might be a good option if your m2y4 OEM tranny is shot (synchros, shiftforks) and you don't want to rebuild it.
Old May 31, 2005 | 08:37 PM
94_HATCH's Avatar
If i had the money i would get a quaife or kaaz. If your on a budget you cold try the obx lsd, same design as the quaife but quality is not the same. If you search there have already been a few threads on the obx lsd working fine without breaking anything.
vtecracer1
Transmission & Drivetrain
Jan 5, 2014 12:51 AM
i-VTEC_do_you
10
Jun 1, 2010 06:18 PM
Ruben19
Jan 15, 2007 04:59 AM
95lstegman
Feb 3, 2005 11:18 AM
TeamSTEALTH GSR
May 21, 2003 09:17 AM
