Low idle?
Old Oct 28, 2003 | 05:28 PM
Too_Funny's Avatar
Default Low idle?
Recently my idle is really low. I estimate its at around 500-600 rpm. Also when I step on the gas and let off the idle would fall until it almost stall before it picks up again. I check the IAC and even replaced it but that didn't help. I have no clue what is going on. I thought maybe you guys can help before Honda charges me an arm and an leg to fix this problem. BTW--This is for a 97 Prelude. Thanks.
Old Oct 28, 2003 | 06:49 PM
00LudeSH's Avatar
Default Re: Low idle? (Too_Funny)
my 2000 sh usually idles around 500 rpms. i don't think that's abnormal.
Old Oct 29, 2003 | 07:20 AM
FoxRiderH22A's Avatar
thats normal...happens in a lot of Hondas. My 97 Base Prelude does it. my friend's Civic SI does it...its a honda thing
Old Oct 31, 2003 | 03:33 PM
jdm22vtec's Avatar
why dont u just adjust the idle??...u can turn the screw on the throttle body with a flat head to raise it.
Old Oct 31, 2003 | 08:35 PM
NoLipRacen's Avatar
Default Re: Low idle? (jdm22vtec)
nuthin big to worry about my car does the same thing and it gets real nasty when i turn on the A/C (only for the ladies), at least you dont have my friends sentra the idle bounces around from 500-2000rpm totally random its actually pretty funny
Old Nov 2, 2003 | 12:13 PM
EGinNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm22vtec &raquo;</TD></TR><TR><TD CLASS="quote">why dont u just adjust the idle??...u can turn the screw on the throttle body with a flat head to raise it. </TD></TR></TABLE>
Old Nov 2, 2003 | 07:32 PM
specalk's Avatar
my 97 does it as well i thought the engine was about to take a **** on me, thankgod its normal. someone told me i needed to set the base line idle and that would correct that, ive got 76k and ive never had a valve adjustment.
Old Nov 7, 2003 | 09:18 AM
steevo's Avatar
i've got one that actually dies when the idle drops. it's got a jackson racing blower and a 8.5lb flywheel so i figure it's probably the same prob. that everyone else has but with the parasitic drag of the blower and the reduced inertia from the light flywheel it can't recover before it quits. i've tested everything & it all checks out. i even threw a new IAV at it and a new throttle body gasket with no results. also, you guys should know that you're supposed to unplug the IAV before you make adjustments to the idle screw, otherwise the computer just compensates. of course the ck. engine light needs to be reset when you're done. htat's what the book says, anyway.
Old Nov 13, 2003 | 01:53 AM
j scratch's Avatar
i had the same problem i replaced the o2 sensor and it idel perfect my aws always was acting up evertime i turned my car off...that problem is no more also.go figure.
frogeye
Feb 11, 2014 08:45 AM
89civicstd
Nov 13, 2013 03:56 PM
turboprelude97
Nov 3, 2008 05:52 PM
turbo Si
Jun 1, 2005 09:07 AM
jakers
Dec 15, 2004 05:28 PM
