Low Beams
Old Oct 8, 2006 | 10:55 AM
GraphiteMW's Avatar
Default Low beams not working and turning signals all messed up
Both of my low beams don't work, I tried replacing the fuses and the bulbs, still a no good.
and
My turning signals is pretty much screwed up, I turn on the hazard light and it works.. but when I turn on my left turn signal it makes both front turn signals flash and on the dash it blinks and ticks fast as hell compared to the right turn signal which works just fine. I also forgot to mention that my high beam indicator doesnt come on when I turn the high beams on.
I'm getting slowly irritated with my buy because this prelude has allot of problems that the seller didnt address to me and its way to late to get my money back. So I'm just gonna fix everything and earn some mechanic experience.
Modified by GraphiteMW at 4:36 PM 10/17/2006
Modified by GraphiteMW at 2:17 PM 10/18/2006
Old Oct 8, 2006 | 10:59 AM
Duane_in_Japan's Avatar
Default Re: Low Beams (GraphiteMW)
follow the post below yours. same prob, almost.
Old Oct 10, 2006 | 05:34 PM
GraphiteMW's Avatar
I discovered something new, since I was checking mainly during the day. Today I went into my car and cleaned up my handy tool box that had tools scattered all over my inside. So I turned on my low beams nothing, switch it to high, High beams comes on.. But I noticed something.. My High beam indicators don't even come on. What does this mean?
Old Oct 17, 2006 | 03:37 PM
GraphiteMW's Avatar
bump with new problems dealing with headlights/turning signals.
Old Oct 17, 2006 | 03:53 PM
WhiteBB2's Avatar
Default Re: (GraphiteMW)
relay? try taking the abs relay out and plugging it into the headlight relay.
Old Oct 17, 2006 | 04:33 PM
GraphiteMW's Avatar
Default Re: (WhiteBB2)
What exactly is that? I'm not too good with electrical things on cars.
BTW, I got my signal lights to work. Now I gotta fix these damn low beams so I can drive at night.
Old Oct 17, 2006 | 06:41 PM
WhiteBB2's Avatar
the relay is in the fuse box under the hood...its a 4 pin square looking thing. one says headlamp and the other says abs...take the abs one out, and the headlamp one, then plug the abs one into the headlamp spot and see if it works...if it doesnt then make sure you put the right one back in the right spot lol.
Old Oct 18, 2006 | 01:18 PM
GraphiteMW's Avatar
The little boxes with the clear tops? I noticed that my headlight "relay" where it has those copper flanges it partially snapped off and barely passes by the screw holes where it holds it still.. How can I replace this? This might be the problem hmm..
Old Oct 18, 2006 | 01:42 PM
WhiteBB2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteMW &raquo;</TD></TR><TR><TD CLASS="quote">The little boxes with the clear tops? I noticed that my headlight "relay" where it has those copper flanges it partially snapped off and barely passes by the screw holes where it holds it still.. How can I replace this? This might be the problem hmm..</TD></TR></TABLE>
No, Thats not what I am talking about. If you look under the hood you have a fuse box. (Pass side, towards the windsheild) The fuse box lid/cover should have a diagram on it. Look for the Headlamp relay and the abs relay...
Old Oct 20, 2006 | 02:56 AM
GraphiteMW's Avatar
I plugged in the ABS one and tried and nothing different happened, the low beams still didnt work but the high's did.
Old Oct 20, 2006 | 04:23 AM
kulrevon's Avatar
there is a grounding point/ a little. block it is bolted to the fender well close to the headlight on the passenger side. I think there is one on the drivers side too.
When it is not connected alot of screwy things happen with the lights.
I think its number 24/48
If anyone has a real picture it would be great
its the white thing. make sure you have one mounted on each side.
Modified by kulrevon at 9:43 AM 10/20/2006
Old Oct 20, 2006 | 12:06 PM
GraphiteMW's Avatar
Thanks, I checked them and both of the grounds are perfectly connected.. Someone suggest that I wire up a ground wire coming from thet low beam wires and have the ground wired to the chassis.
Farquea
11
Nov 14, 2021 12:24 PM
Mister_1
Honda Civic (2006 - 2015)
Jun 5, 2018 05:36 PM
Acethriller
Lighting
Jan 4, 2014 07:58 PM
KidZr0
10
Mar 29, 2013 11:52 PM
KidZr0
Lighting
Mar 28, 2013 10:37 AM
