Lightweight Battery
Im looking into Odyssey batteries, I wanted to know what is the lightest one that will provide enough wattage to turn the car over,especially on cold mornings.
Get an Odyssey PC-680.
Very thin and light (for a battery) and mine cranks my car over like any other large battery.
You can pick them up at Batteries+ stores if you have any near you.
Very thin and light (for a battery) and mine cranks my car over like any other large battery.You can pick them up at Batteries+ stores if you have any near you.
Something that I had just thought of. I was watching one of those car shows and they were breaking a newer CTS-V I think and remember seeing the battery with a wrap around it. Kinda like an insulator.
So I was thinking that if you do end up with one of these smaller batteries and are worried about the cold cranking. Maybe fab up a little insulator blanket for it.....?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 »</TD></TR><TR><TD CLASS="quote">agree w/ hawk
odyssey 680... starts my car in ANY weather (30-90 degrees)
where the hell is your battery?
i th\ink ib ought it for 70-90$ including terminals off ebay
got creative w/ the mounts.. haven't had a problem since... can remove battery in less than 5 mins
Well if its ok in colorado im sure ill be ok in Pa. Where did u run ur wire under the passenger side panel and through the same hole as the wiring harness ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH »</TD></TR><TR><TD CLASS="quote">Well if its ok in colorado im sure ill be ok in Pa. Where did u run ur wire under the passenger side panel and through the same hole as the wiring harness ? </TD></TR></TABLE>
Mine is mounted in the trunk and I ran the wire through the same gromett as the wire harness then back to the trunk.
Also if anyone has a picture of their battery mounted in the trunk that would help. Because I think that one i posted before looks cool but idk where a flat place to mount it would be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 »</TD></TR><TR><TD CLASS="quote">
Mine is mounted in the trunk and I ran the wire through the same gromett as the wire harness then back to the trunk.</TD></TR></TABLE>
Howd u run the wires through the cabin ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH »</TD></TR><TR><TD CLASS="quote">damm....has anyone else had problems liek that ? </TD></TR></TABLE>
I had a Braille battery die on me after a year or so, but that thing was rediculously small. My first 680 lasted 2 years with a bad alternator and daily driving.
And it really is pointless to put a lightweight battery in the trunk...you can find a place in your bay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 »</TD></TR><TR><TD CLASS="quote">lightweight battery + trunk = waste of money
if ur gonna relocate it, might as well keep stock battery for power...
lightweight one died in the carwash once
I did it for space constraints, Now I have just enough room.
</TD></TR></TABLE>I did it for space constraints, Now I have just enough room.
