kyb agx shocks...
Old Feb 10, 2003 | 03:19 PM
sslude's Avatar
Default kyb agx shocks...
what would be a good setting to put it at, i have a 1.5in. drop if that matters at all. i want it to be stiff, but at a safe setting. can you guys recommend a setting for both front and rear. gracias. and i would like to see a pic of them if any of you have any, thanks
Old Feb 10, 2003 | 04:03 PM
Gennady's Avatar
New User
Default Re: kyb agx shocks... (sslude)
I used to have 2f/4r, but it really depends on what you have. Why take someone elses advice when you can just judge for yourself with a little trial and error?
Old Feb 10, 2003 | 04:06 PM
RAB's Avatar
RAB
First of all great choice with the shock setup. As you probably know I think you're right a the KYB lower limit before the warrenty is void. So be cautious with them (i.e. don't set them stiff and go over a series of bumps.) I occationally drive around with my setting at 4 (stiffy). Honestly I've never played around with them to find an equilibrium pt. Maybe at this sunday's auto-x I set the front stiff and the rear less stiff.
Ask corey (the infamous mod) he can help you with suspension stuff, just don't be a noobie.
sslude's Avatar
Default Re: kyb agx shocks... (Wont be beat)
okay, welli dont have them yet. how do you change he settings? is it really as easy as people say it is? and how much different settings are there, i heard that it was 8 in back and 4 in front. thanks
Old Feb 10, 2003 | 05:45 PM
stoopid215's Avatar
i think it is 4 in front, 8 in back .. mines set at 2/2
Old Feb 10, 2003 | 06:25 PM
DsITR's Avatar
Default Re: kyb agx shocks... (stoopid215)
On mine...there are only 4 settings both front and back..
You guys are talking about KYB's right??
For daily driving I set 3 front 3 back..@ is too soft for me, I like to drive like an ***.
Old Feb 10, 2003 | 06:45 PM
Tekwon-V's Avatar
Default Re: kyb agx shocks... (dsludefosho)
i have agx/prokit combo.
during this 24hr auto-x event i attended 6 months ago, i was able to play around with the settings as i was able to run 10+ times. i tried every possible combos.
for auto-x / spirited driving... i use 3F and 4R (i think for all prelude applications.. they are 4-way adj not 8) the rear kicks out slightly during turns and it's very manageable. i love it.
for highway driving... 1F 1R for that smoothness(although it's still stiffer than stocks ones)
Old Feb 11, 2003 | 06:39 AM
Daemione's Avatar
How you set them isn't as dependent on the ride height as it is on the spring rate . . . . For summer driving on my H&R sports, 2 all around is just about the right amount of damping for street driving, and 3 all around if I know the roads I'm going to be on are somewhat forgiving. I don't find I need to set the rear's any stiffer than the front to maintain a fairly neutral handling demeanor.
It's worth noting, they're very temperature dependent. Once it gets to be about 30 or 40 degrees, they feel as if they're set a notch or two stiffer than they really are. Below 0 degrees, you'll swear they're set at about 9. On a real hot summer day (100+), I can set them to max stiffness & ride around in relative comfort.
Of course, all of the above is subjective, and skewed by bushing & spring compliance at different temperatures.
Old Feb 11, 2003 | 06:51 AM
Honda318dx's Avatar
Default Re: kyb agx shocks... (Tekwon-V)
Bingo, this is pretty much the way they are..
Corey- who had AGX's for years, and even won a ECHC race or two w/ them..
Old Feb 11, 2003 | 02:35 PM
sslude's Avatar
Default Re: kyb agx shocks... (Honda318dx)
does the ride height change at all when changing the settings? thanks
Old Feb 11, 2003 | 02:41 PM
mt23vtecbb2's Avatar
a little bit. mine are at 3 on all corners
Old Feb 11, 2003 | 04:21 PM
Daemione's Avatar
Default Re: kyb agx shocks... (mt23vtecbb2)
a little bit.
No, it doesn't.
Old Feb 11, 2003 | 07:24 PM
sslude's Avatar
Default Re: kyb agx shocks... (Daemione)
how hard is it to change the settings? how do you change the settings? and where di dyou guys get them and for how mcuh?
Old Feb 11, 2003 | 08:58 PM
stoopid215's Avatar
u take the tiny screwdriver they give u and turn the little **** on the strut...
[Modified by stoopid215, 9:58 PM 2/11/2003]
power11
Suspension & Brakes
Jul 14, 2007 03:42 PM
dtrtw
May 22, 2005 11:31 AM
mikehawkBUiLT
42
Jun 4, 2004 08:55 PM
akeldama
Dec 30, 2002 09:49 PM
visual
Dec 25, 2002 10:36 AM
