Knock Sensor INSTALL advice
hey everyone. broke my sensor in half i guess from driving about 2 weeks ago and got a new one. trying to figure out if its easyier to get at it from the top (remove intake manifold) or down below. i need to do an oil change anyways if from the bottom and removing oil filter.
so anyone done this before got some words of advice, tips n tricks ?
thanks !!!
thanks !!!
yeah that seems to be the easyiest way from the way i kept looking at the two angles. man being 6'2 and having big hands n feet (13's) helps nothing on a honda cept messd up heel toe-ing and the constant irritation of NOT being able to reach or do anything easily under the hood hahaha - thanks !
Go at it from the bottom and make sure you have the right size deep socket. I did mine a while ago and it's pretty easy if the oil filter is off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallazzFilipino »</TD></TR><TR><TD CLASS="quote">what engine is it for? i did mine from tha top (leavin' intake manifold and oil filter on) for a b16. i'm 6'6" by tha way.
_taF</TD></TR></TABLE>
It's probably for an H/F engine seeing as how this is the Prelude forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Go at it from the bottom and make sure you have the right size deep socket. I did mine a while ago and it's pretty easy if the oil filter is off.
I believe it's a 21mm socket since I just swapped one out of an H22a this past weekend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest »</TD></TR><TR><TD CLASS="quote">I believe it's a 21mm socket since I just swapped one out of an H22a this past weekend.
oh, i thought it was 23mm, its been soooo long since i worried about knock sensors (have a p28
</TD></TR></TABLE>oh, i thought it was 23mm, its been soooo long since i worried about knock sensors (have a p28
yoo..i have asuggestion...and it worked for me. Use some really good epoxy around theknock sensor...where the plastic and metal meet. the KS is known for breaking and ****, so adding soem epoxy will def stregthen up the bond. Its just a suggestion
I believe it's a 21mm socket since I just swapped one out of an H22a this past weekend. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">
oh, i thought it was 23mm, its been soooo long since i worried about knock sensors (have a p28 )</TD></TR></TABLE>
Its actually 27mm, I just measured the 2 broken ones that are laying in my toolbox haha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">It's probably for an H/F engine seeing as how this is the Prelude forum.
my bad. i thought i was in tha 92+ Civic forum.
_taF
_taF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 »</TD></TR><TR><TD CLASS="quote">Yep 27mm for obd1.</TD></TR></TABLE>
Now that I think of it, it could have been 27mm. It wasn't an OEM knock sensor, but we used a 1 1/16th socket and that fit it. Wierd.
Well, 27mm = 1.063 inches which just so happens to equal 1-1/16 (or within .0005 of it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko »</TD></TR><TR><TD CLASS="quote">
Well, 27mm = 1.063 inches which just so happens to equal 1-1/16 (or within .0005 of it)</TD></TR></TABLE>
My math isn't that good, but my luck was! I don't think I even have a 27mm socket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">lucky ******* that can do things from the bottom.....</TD></TR></TABLE>
Would you hate me if I said I have access to a lift and air tools, as well?
CaptivaBlue
Oct 6, 2004 03:27 PM
