injector harness
hello,
i have a type s engine, and i am attempting to change the 280cc injectors, to the 345 peak and hold injectors from the obdI prelude. i have the fuel rail off, and the injectors are not cliping into the harness. is there any way to safely clip the injectors in (for example; remove the outboard clip) to the obdII harness, or am i going to have to flip the bill for an obdI injector harness? also are the injector resistors located in the injector harness? thanks
adam
Modified by adam meyer at 3:25 AM 11/4/2003
adam
OBD II type s? well either way if you are using an OBD II harness yes you will need obd I injector clips..... You can pick up some obd I injector clips at a junk yard if you want for a few bucks and hard wire them in with some inline 10-20watt 10 ohm resistors... Do a search if you want there have been plenty of resitor and injector clip install threads....
-Jeff-
-Jeff-
thunderboy
May 15, 2011 06:39 AM
