Igniter/ECU
Old Mar 3, 2004 | 08:18 PM
Spy1r's Avatar
Default Igniter/ECU
Car completley died on me. Checked for spark adn it has none. I took a look at my ECU (I just had a fealing) and it had short circuited. Traced the problem from a wire on the distributor and it led to the part of the ecu that had shorted. My question is coud a bad igniter have done this? Also my positive terminal on my battery was loose. Could this have caused the ECU to short? Ordered a new ECU but do not want to have a repeat of the same poblem. What do I do?
Old Mar 3, 2004 | 08:20 PM
poison's Avatar
Default Re: Igniter/ECU (Spy1r)
I doubt it. do you have all the proper fuses? check fuses. and don't ever install a higher amperage fuse.
the ecu shouldn't blow if you have correct amperage.
Old Mar 3, 2004 | 08:30 PM
Spy1r's Avatar
Fuses are all good, followed the Chilton manuel on all the trouble shooting for the ignition system, but everything seemed to be working fine.
RIOredKIRKLANDcrx
Feb 11, 2004 05:46 PM
killa_lude
Jan 10, 2004 12:45 PM
CTR_EK9
Feb 24, 2003 04:14 PM
Rukusmasta2
Feb 17, 2003 03:01 PM
