Identifying a small piece
Old Dec 6, 2006 | 09:21 AM
ZXRider's Avatar
Default Identifying a small piece
Could someone name the piece with a question mark next to it for me? I got these parts back from my machine shop when they rebuilt my cylinder head. I know I have to re-use the sensor, down pins and the oil orifice but what is the last piece? do I need to re-use that also?
Also, is it crucial to use a new exhaust manifold gasket or could I re-use my old one.
Thanks
Old Dec 6, 2006 | 09:39 AM
Slomies's Avatar
valve seal ... no you dont have to reuse it, as long as the machine shop installed all of them again. if I were you, I'd make sure that they installed all of them ...
Old Dec 6, 2006 | 11:15 AM
ZXRider's Avatar
Default Re: (Slomies)
Well he told me he changed all of the old seals with new ones. I had one bent valve and he replaced that bent valve. He gave me back the bent valve and all the stuff you see in the picture. I'm wondering if he only changed just one valve and told me he changed out all of them.....
is there anyway I could visually inspect the cylinder head and see the seals and be able to tell if they are changed or not? I will call the shop later today to verify and make sure he changed all the seals, im just curious why he gave me a single valve seal back, if he wanted to give me all the replace parts back why didn't he just give me all 16 of them back.
Thanks for the help.
Old Dec 6, 2006 | 12:19 PM
mgags7's Avatar
The thing with the question mark pointing to it is a valve stem seal
Its going to be tough to figure out which he changed and which he didn't with the cams, springs, and retainers in the way....
Old Dec 6, 2006 | 01:44 PM
ZXRider's Avatar
Default Re: (bb4ever)
I haven't installed the head yet. It's sitting in my room currently without anything.
Here are some pictures of it.
Old Dec 6, 2006 | 02:46 PM
Eddiebx's Avatar
i guess u can try and peek between the springs and see if u can tell if all the valve seals are clean and new.
91SIR
Nov 24, 2013 09:06 AM
Jackrabbit4
Jun 22, 2013 08:09 AM
si937
Jul 25, 2006 02:18 PM
SYN4DRDX
Jul 9, 2005 12:09 PM
LudeyKrus
Jul 21, 2003 12:32 AM
