How to: Remove A/C compressor
Old Dec 27, 2004 | 01:33 PM
92hondalude's Avatar
Default How to: Remove A/C compressor
ok today i started to remove the ac compressor and i thought i would make a DIY guide so here it is.
lossen this bolt i used a 12 mm wrench
lossent the bolt (in red) and then loosen the bolt in yellow till you can take the belt off. i used a 12 mm wrench
this bolt is located under the wiring of the altornator loosen this bold i used a 12 mm wrench
There is a bold on the back of the altornator but i could not get a pic of it i used a 14 mm with a 1 in extenchen
This bolt will tighten and untighten the belt to untighten it you lossen it. To tighten it you tighten up the bolt i used a 10 mm wrench
This is only half of the guide i will update it when i finish with the project
Modified by 92hondalude at 10:56 AM 12/28/2004
Old Dec 27, 2004 | 10:04 PM
PrettyLude's Avatar
good write for newbs
Old Dec 28, 2004 | 05:54 AM
mgags7's Avatar
what does 12mm mean in metric?? im having trouble converting
haha yeah good write for the 2004 members, oh ****, wait i am one, well 99% of the 2004 members....
Old Dec 28, 2004 | 06:59 AM
Default Re: (mgags7)
thanks i will finish the write up when i get a A/C guy to come take the r12 out or i might just say f*** it and and just put a screw driver to it, to empty it out
WaryDriver
Aug 8, 2015 06:18 AM
gezatozser
Honda CR-V & Element
May 3, 2015 04:31 PM
Rover2cool
Mar 13, 2013 06:46 AM
Schultzie
Aug 5, 2007 07:44 PM
Renegade
15
Sep 22, 2003 06:28 AM
