How to get started??????
Old Dec 2, 2008 | 10:14 AM
PreludeTech33's Avatar
Default How to get started??????
Hey guys, I need some help. I bought a 92 honda prelude from a guy a while back and the car had a blown head gasket. He didn't have much time to fool with the car, so I bought it from him. Naturally, I wanted to find a swap, so I put in the stock h23 with auto tranny in the car. I flushed the heater core and hoses out, I cleaned the firewall, frame, etc so the install would go smoother. I bought a new timing belt, tensioner, water pump, seals, plugs, plug wires, cap, and everything else I needed. I guess the car is cold-natured because when I crank her up in the morning, she idles high. I have no more power steering because there is a leak somewhere. I removed my cruise control.
- Should I use Lucas Oil Stabilizer with my engine oil?
- What about the tranny?
- What kind of coolant should I run?
- Im lost with this car?
-Any help is appreciated.
-Thanks
Old Dec 2, 2008 | 10:16 AM
A check off list with the right brand and amounts of products to use would be a plus.
-Thanks again
Old Dec 2, 2008 | 10:36 AM
meanshyguy's Avatar
Does your Idle bounce when the car is cold or it's just high? Is should go back to normal after it gets hot.
Any mixture of 50/50 water or coolant would be good
I don't see the point on using oil stabilizer, how does the engine run?
Old Dec 2, 2008 | 10:51 AM
crazes's Avatar
Moderator
if its cold its ok for it start slighty high like 1500-2000rpm but after warming up it should drop to about 600-800rpm. or if it is bouncing check to see if the tb is dirty i had that issue with mine tb. check to make sure the butterfly isn't dirty and the spring that inside isn't sticking cause its dirty.
Old Dec 3, 2008 | 01:15 AM
meanshyguy's Avatar
If idle keeps bouncing, also check your FITV, it's under your TB, you can clean it up as well, there's a write up on how to do it, search!!
Old Dec 3, 2008 | 10:54 PM
BlackCatt's Avatar
Re: Coolant. I only use Honda coolant and highly recommend it. Its not expensive and i dont want to run the risk of getting any corrosion like i had in my 2nd gen, which a previous owner had let run on a 50% water / 50% aftermarket coolant mix (and i suspect sometimes just water alone). Last time i picked up coolant from honda i found you no longer need to mix it with water, it comes ready to go. My 4th gen was serviced by honda until i was lucky enough to buy it, and the cooling system is in great condition considering the engine has 290,000 Km on it.
Old Dec 4, 2008 | 12:11 AM
BLUBB2's Avatar
1.Dont run that s***.Its junk.
2.Dexron 3 ATF
3.50/50
4.lol are you?
BiG_DeE
15
Aug 30, 2010 11:45 AM
wallabee32
Nov 25, 2008 06:29 PM
Crackback
Nov 20, 2008 03:45 PM
mstewar
Jan 1, 2006 11:18 AM
roadracer65
Aug 23, 2002 06:51 AM
