How do I obtain/pull the codes from the ECM
Old Mar 14, 2004 | 06:20 PM
toolpusher's Avatar
Default How do I obtain/pull the codes from the ECM
I have a 1990 prelude. I need to know the procedure to get the trouble codes from the ECM.
What does ODB mean?
This is the first Honda car I have ever owned.
I had no idea these cars would perform like they do!
Old Mar 14, 2004 | 06:47 PM
hOndafienD 04's Avatar
snap on scanner!!! take it to a shop that has 1...
you got OBD1 which means "on board diagnostics"
Old Mar 14, 2004 | 06:56 PM
RHD_BB4T's Avatar
Default Re: (hOndafienD 04)
I think that you are incorrect...
1990 = NON OBD
OBD-I came out in 1992 model Preludes if I'm not mistaken... please correct me if I'm wrong!
OBD = On Board Diagnostics (Mostly emissions related)
OBD-I : 92-96
OBD-II: 96-on
The years might be off by one or two though, that's just off the top of my head...
The NON-OBD ECU's should have the flashing LED to show you the indicated code.
dp.-
Old Mar 14, 2004 | 07:20 PM
jdmlude_dude's Avatar
Default Re: (RHD_BB4T)
there is a such thing as OBD-0. it is the first OBD setup... not sure if a 90 lude has it or not. I hvae heard of OBD-0 though.
Old Mar 14, 2004 | 07:21 PM
RAB's Avatar
RAB
Default Re: (jdmlude_dude)
http://www.hondaprelude.to/art....html
Old Mar 14, 2004 | 09:04 PM
missdusty's Avatar
Default Re: How do I obtain/pull the codes from the ECM (toolpusher)
A 1990 Prelude is OBD-0
91 and older = OBD-0
92-96 = OBD-1
96 and up = OBD-2
On your ECU, (this works for crxs and civics, i'm not 100% sure it works it works with preludes) which is probably under your passenger side carpet (there is also probably a metal covering protecting the ECU which is held on by a few bolts) othere is a little red light that will blink if your check engine light is on. A long blink is a "10" and a short blink is a "1," so if it blinks "long long short short short" that is a code 23. I think that link will tell you what a few common codes mean, if not there are other links, probably easily accessible on this site.
Jdmefsir12
Jun 30, 2012 12:44 PM
4dOoR-Ex
Jan 29, 2007 01:25 PM
bluelsvtecda9
Jan 4, 2007 07:55 AM
4drEF
10
Aug 26, 2004 10:04 AM
-16V-
Oct 21, 2002 04:36 AM
