HOW CAN THIS BE?!!?
Old Apr 26, 2011 | 04:44 PM
Star's Avatar
Default HOW CAN THIS BE?!!?
3rd time my clutch went out in one week.
1st time the person put it on with the throwout barring on backwards. it went out
2nd time my clutch rod went out
today on my way home it just went out again ALL IN ONE WEEK?!?!
(Raplaced clutch, slave cylinder, master cylinder)
1992 Prelude Si 4WS H23a1. non-vtec, can any1 help me out?? PLEASE!!
Old Apr 27, 2011 | 01:02 PM
Prelude01h22's Avatar
Default Re: HOW CAN THIS BE?!!?
buy an automatic. Seriously thats bad luck.
Old Apr 27, 2011 | 02:17 PM
Luded93's Avatar
Any oil in the bell housing?
Old Apr 27, 2011 | 06:57 PM
codyh's Avatar
formerly xmod_supra
Get off.
Old Apr 27, 2011 | 09:01 PM
mike541's Avatar
That's nothing... you should hear the luck I have!! Feel fortunate! Now you'll have all new parts!
Old Apr 27, 2011 | 10:19 PM
holmesnmanny's Avatar
I feel you, man. I have some of the worst luck as well. Now I just try to take a little bit long to do everything and hope I catch the mistakes I would otherwise make.
Old Apr 28, 2011 | 05:45 AM
typemismatch's Avatar
Honda owns me
*facepalm*
you fail
Old Apr 28, 2011 | 02:11 PM
Originally Posted by typemismatch
*facepalm*
you fail
*Stabs you in the face*
your dead
Old Apr 28, 2011 | 06:00 PM
codyh's Avatar
formerly xmod_supra
your dead
you suggested someone switch to automatic. That was a stupid piece of advice, therefore it makes you look like you lack basic intelligence. And you clearly are a psychopath. So again get off. And dont come back. Kthxby
Old Apr 28, 2011 | 06:29 PM
blackedEk's Avatar
and you came in here to keep the argument going.. Good job
Old Apr 29, 2011 | 06:50 AM
snobordboy's Avatar
Moderator
I would suggest just having a good mechanic take a look at it, sounds like this is all the product of poorly done work.
Old May 1, 2011 | 02:41 AM
2nd one's Avatar
^^^i was thinking the same thing. slave and master are usually done at the same time. common sense and you only need to bleed the system once. (bench bleed the master prior to install). bleed the system of air thoroughly. hydraulic system should be fine afterwards. putting the throwout bearing on backwards you would think would be obvious as the fork will not seat properly but regardless.
Old May 1, 2011 | 07:54 AM
mherkamp's Avatar
If the master cyl. was replaced, make sure that the clutch rod is not too long. Its adjustable and if too long, will not allow fluid to flow back into the reservoir. Had that happen when I did my 5spd swap and the clutch would slip when it got warm under the hood. Would bleed the system and let off the excess pressure, and it would work again.
Old May 1, 2011 | 07:57 AM
Suprasnuffer's Avatar
automatic prelude,,that sounds lik a gurls type of ride
RipSiTurboHatch
Apr 2, 2009 11:19 AM
Ri5e
10
Sep 22, 2004 05:36 AM
migs
Feb 20, 2003 10:49 PM
slimmy
Oct 24, 2001 12:57 AM
