Hondata question
Old Apr 10, 2006 | 11:56 PM
jdmludeaz's Avatar
Default Hondata question
I have a p13 chipped. So would it be pointless to install the s200 hondata in my h23a lude. What kinda effects would happened?
Old Apr 11, 2006 | 12:11 AM
hu's Avatar
hu
Ask PrecisionH23a. He is a moderator here. He is also authorized to carry/sell Hondata products. Get a p28 ecu. I think Hondata simply doesn't support the p13 ecu.
Modified by hu at 3:24 PM 4/11/2006
Old Apr 11, 2006 | 03:32 AM
98vtec's Avatar
moderator emeritus
Default Re: (hu)
nope, no support for the p13. For an h23, you want to run a pr4, p74, p75. There are other vtec ecu's that you can use and just disable vtec but the 3 a listed are the easiest.
Old Apr 11, 2006 | 04:03 AM
v4lu3s's Avatar
RTFM
i would probably use the p08/28/30/72 since those have vtec control.
Old Apr 11, 2006 | 05:28 AM
98vtec's Avatar
moderator emeritus
Default Re: (v4lu3s)
he doesnt need vtec control, he has an h23
Old Apr 11, 2006 | 07:20 AM
SpeedFreak77's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">nope, no support for the p13. For an h23, you want to run a pr4, p74, p75. There are other vtec ecu's that you can use and just disable vtec but the 3 a listed are the easiest.</TD></TR></TABLE>
Not to mention that they are probably cheaper than the vtec ecu's. You can also go to the Hondata website and they have a list of ecu's they support and what is recommended for your application.
Old Apr 11, 2006 | 07:52 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">he doesnt need vtec control, he has an h23</TD></TR></TABLE>
I read h23a which is a dohc vtec engine usually, which also explains why he is running his engine with a p13.....
Old Apr 11, 2006 | 08:44 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">I read h23a which is a dohc vtec engine usually, which also explains why he is running his engine with a p13.....</TD></TR></TABLE>
maybe he can enlighten us
Old Apr 11, 2006 | 09:27 AM
BB4-Japanpower's Avatar
who can tell me what ecu should i use if i dont want to disable the knock sensor
Old Apr 11, 2006 | 09:34 AM
hu's Avatar
hu
For the H22 you would use a P72. Do some checking around. A lot of tuners disable the knock sensor because it is ineffective at higher speeds.
Old Apr 11, 2006 | 10:22 AM
PrecisionH23a's Avatar
Default Re: Hondata question (jdmludeaz)
p72 for knock sensor
p28 for no knock sensor
H23a is non-vtec, I usually run the p74 or p75 on these. The hondata unit is always beneficial to any engine that has aftermarket mods.
music462
May 18, 2016 04:23 AM
stpacura
Mar 10, 2008 10:09 AM
99SlammedCivic
Aug 28, 2004 12:19 AM
squirrel
Jun 26, 2004 12:33 AM
symba
Apr 21, 2003 12:49 PM
