Hid Fog Problem.
Old Sep 11, 2011 | 12:32 PM
bennyBronco's Avatar
Default Hid Fog Problem.
I've purchased this 5th gen with HID fog lights. The fog lights would turn on when the car was on, and would turn off when i turn the car off. Lately i would turn my car off and walk away. When i turn back to wave goodbye to my car, i noticed the foglights are still on. I would then have to start my car and manually turn the fog lights off by toggling with the button. Does anyone know whats going on?
Old Sep 11, 2011 | 05:04 PM
DJ_SaNdOz's Avatar
Default Re: Hid Fog Problem.
I'd start at the fuse block where the switch is wired to to make sure that the switch wiring is firmly seated in a switched power slot. From there trace the wires as needed to make sure that there are no frays or other problems that could interfere with normal operation. Luckily with lights there is not much wiring involved, and only so many junctions so should be easy to diagnose.
Old Sep 11, 2011 | 07:09 PM
I've traced all the fuses and relays pulled it apart and i didnt find anything out of place. The fogs staying on is so annoying, im used to just jumping out my car and walking away, now i have to remember to turn them off.
Old Oct 1, 2011 | 01:20 AM
99preludeowner's Avatar
are you sure you plug it on the right power source? dont plug it where the alarm goes (if you have one) because that plug still supplies power even the car is off. I think I plug mine on plug # 2 it only supply power when ignition in on accessories and its cuts off when key is removed
here's where I got my idea
http://www.hondaprelude.to/articles/...l/jdmfogs.html
Old Oct 1, 2011 | 05:35 AM
heyy thanks a lot for the help guys... i just replaced the relay and its all fine and dandy. the relay still looked fresh, ish what went on.
redfire106
18
Sep 6, 2012 01:10 PM
cheap_noob
May 5, 2012 02:48 PM
mynameizstitch
Aug 24, 2010 07:20 PM
pjr710
Aug 24, 2007 05:45 PM
92blackg2
Jul 16, 2005 06:24 AM
