Help? Removal PS
Old Mar 9, 2010 | 10:17 AM
toukao35's Avatar
Icon3 Help? Removal PS
I was looking in the FAQ and i couldnt find a link where it showed me how to remove the line from powersteering or how to remove the ps belt, so that the the ps would not work. I don't want to remove the ps but just disconnect it, so there would not be any ps. I saw it on another car...how would you do that to a bb6 sh prelude?
Old Mar 9, 2010 | 07:21 PM
the boogler's Avatar
Default Re: Help? Removal PS
remove belt
Old Mar 10, 2010 | 05:17 AM
ilikehonda's Avatar
there is an adjustment bolt on the ps pump...loosen it and pull the belt off
Old Mar 10, 2010 | 07:30 AM
NirVTEC's Avatar
I hope you don't have to parallel park.....
Old Mar 10, 2010 | 09:57 AM
toukao35's Avatar
thnks that helps...haha i hope i dnt have 2 paralell park too...lmao
Old Mar 10, 2010 | 11:46 AM
toukao35's Avatar
how would u loosten the bolt, when the powersteering belt moves with it?
Old Mar 10, 2010 | 12:03 PM
ilikehonda's Avatar
so you can relieve the tension on the belt and remove it..........
Old Mar 10, 2010 | 01:19 PM
toukao35's Avatar
so just hold the ps belt and loosen the bolt?
Old Mar 10, 2010 | 01:55 PM
toukao35's Avatar
i cant seem to unloosen the bolt..it tried but it would get lossen could i just cut it off?
Old Mar 10, 2010 | 03:55 PM
ilikehonda's Avatar
not unless you want to buy another bolt. get a breaker bar
Old Mar 10, 2010 | 04:19 PM
Enzo15's Avatar
You guys are talking about 2 different things. Toukao is talking about the Pulley that the belt sits on. Ilikehonda is talking about the bolts that hold the P/S pump to the bracket. Around the P/S pump there are 3 bolts that need to be loosened before you can lower the pump and take off the belt. If you need a picture let me kno, I can go outside and get one for you.
Old Mar 10, 2010 | 05:46 PM
toukao35's Avatar
Ok I got the belt off. Now will there be any problems with the pump or anything else?
Old Mar 11, 2010 | 06:05 AM
ilikehonda's Avatar
nope....just keep everything connected. good luck
kelviiv
Sep 18, 2010 07:41 PM
chinesebwoy
Honda Civic (2001 - 2005)
Apr 17, 2009 01:47 AM
94DB8
Feb 1, 2009 01:33 PM
PYITR821
Jun 3, 2002 01:14 AM
