Help...Overheating at Idle!
Old Jun 7, 2009 | 08:57 AM
kevprelude's Avatar
Default Help...Overheating at Idle!
ok, so i have changed my rad, put a civic aluminium mishimoto....changed the thermostat for the correct 64mm since i have a jdm h22a! also have an electric slimfan wired to a switch so its always on....running ionized water with redline water wetter. Now i have a new water pump from last year, when i swapped the motor, but i bought a jobber :S yea i know stupid move!!! Anyways only thing that is old is the rad hoses...and i gotta admit the bottom one is really soft!!!
so yea the car starts to run hotter than normal when i come to a stop more than 2-3 minutes....if i rev it and push it a bit when i start to drive, temp goes back down!!!
HELP ME I CANT TAKE THIS NO MORE!!
update after a couple of days:
im really getting effin mad!! Still overheats at idle...what weird is i turn the car off...wait 10 seconds, turn the key back on, temp is back to regular!
things ive changed:
gauge sensor
thermostat
rad
hoses
slimfan
rad cap
thing is, the system doesnt seem to be pressurizing! take the cap off and no pressure release!!
Waterpump you think?
Old Jun 7, 2009 | 09:15 AM
drift2004's Avatar
Default Re: Help...Overheating at Idle!
check if ur fan is pushing in the right way? that would be one ofmain issue for over heating, does ur coolent smell like oil? if so it can be ur head gasket
Old Jun 7, 2009 | 11:18 AM
Kronn 98SH's Avatar
No pressure typically indicates that you have a leak in the system. Use a pressure tester to see if a leak appears.
Old Jun 8, 2009 | 01:50 PM
slow96lude's Avatar
deinately pressure check. it could be the tune as well. if its running to lean. does it backfire at all when your slowing down on engine compression
Old Jun 8, 2009 | 09:16 PM
kevprelude's Avatar
yea it backfires....but its not running lean, its running rich!!! back of my car gets black after 2 days!!!
Old Jun 8, 2009 | 10:34 PM
Kronn 98SH's Avatar
Water pump might be bad.
russlan44
Jun 5, 2021 09:19 PM
cafine
Dec 17, 2009 02:37 PM
brookliner7
Nov 10, 2006 09:00 AM
civicstar
Sep 3, 2006 11:47 AM
Bs
17
Aug 9, 2002 11:51 AM
