Help: Installing indigo guage
got a 5gen lude here.
I'm having trouble removing the "black molding" and glass that's covering the factory gauges. There are 2 visible screws holdign the top part of the black molding in place, which can be easily unscrewed; but the bottom part of the black molding is held by something that i can't figure out.
any of you have experience with replacing gauges? or know of a DIY install website?
Any tip would be appreciated. Thanks....
on the bottom there are two black clips, you just need to use a little force to pull them out. be careful not to break them, they will snap back into place when your done. after that there are four more screws to remove the clear plastic covering. be sure not to remove your needles and mark the spots where they are when your car is warm just in case you need to recaliberate them by hand. it's a breeze.
