headers making fluttering noise
Old Aug 2, 2004 | 11:15 PM
andeh22's Avatar
Default header's making fluttering noise
Searched through all 30 some pages for header questions. only found something with ticking noises but nothing that really answers my question.
So now i ask.
I just put in a dc 4-2-1 ss header into my 98 prelude with aem cai and greddy evo2.
After installation there seems to be a fluttering noise when I accelerate. is this normal? if not, then any idea what may be the problem? Seems like a n00b question but not afraid to ask.
Any helpful comments appreciated
Old Aug 3, 2004 | 05:35 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: header's making fluttering noise (andeh22)
It could be anything. What does it sound like? Does it sound like a rattle? Does it make noise while accelerating or decelerating?
Check the following.
* Intake filter - It could be that rattling on the metal frame.
* DC Sports SS header - I don't know about SS, but the CC are known to have hairline cracks and cause rattling. Inspect your flanges.
* Check the heat shields.
* It could be your CAT. CONV also.
Good Luck!
Old Aug 3, 2004 | 12:17 PM
EuRoBrO's Avatar
Dont worry about it man, I have the same noise on my DC and the same noise with my old motor with a OBX header, I think you can just hear the exhaust going through the pipes now with a head rather than a stock cast-iron exhaust manifold.Almost sounds like you have a exhaust leak right?
Old Aug 3, 2004 | 01:11 PM
Inextricabledrvr's Avatar
no it isnt normal if it sounds like a diesel driving by. It could be a cracked flexpipe which is the meshy looking thing before it connects to the cat. The reason i say this is because i bought a dc header used and i encountered this problem also.
I went to a local muffler shop and they told me i will have to replace the flexpipe. I highly recommend putting a spring there instead of a flexpipe because i replaced mine 3 times due to it cracking.
Once i replaced i noticed a dramatic difference.
Oh another thing...modify the collector to a 2.5" and youll notice better gains guaranteed.
good luck i hope that helped.
Old Aug 3, 2004 | 01:29 PM
EuRoBrO's Avatar
Default Re: header's making fluttering noise (Inextricabledrvr)
Well if it is a LOUD noise that is one thing but if it is just a little bit of a noise that is only noticable like when you are driving next to a semi or a cement wall to hear then its normal. Just the sound of the exhaust flowing FREE!!!!
Old Aug 3, 2004 | 02:55 PM
SKDRCR's Avatar
Default Re: header's making fluttering noise (Sticky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">
Good Luck! </TD></TR></TABLE>
Old Aug 3, 2004 | 03:20 PM
rjr162's Avatar
Default Re: header's making fluttering noise (EuRoBrO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EuRoBrO &raquo;</TD></TR><TR><TD CLASS="quote">Dont worry about it man, I have the same noise on my DC and the same noise with my old motor with a OBX header, I think you can just hear the exhaust going through the pipes now with a head rather than a stock cast-iron exhaust manifold.Almost sounds like you have a exhaust leak right?</TD></TR></TABLE>
remember, the stock H22 doesn't come with the manifold like the other hondas....
Old Aug 3, 2004 | 03:53 PM
EuRoBrO's Avatar
Default Re: header's making fluttering noise (rjr162)
Well he is talking about a after market header.
Old Aug 3, 2004 | 07:03 PM
andeh22's Avatar
its a brand new header.
and i can hear it driving on an open road. it makes noise only when accelerating.
it makes the same noise just revving the car which is probably the same thing.. -_-
sounds like.. something is inside just flapping or rattling around with the air, somewhat sounds like a diesel engine.
thanks for the positive and helpful comments.
im going to get it checked. if anyone has other suggestions on what it could be, thanks
Old Aug 3, 2004 | 08:19 PM
MC_HondaRacing's Avatar
I've been driving around on my cheap OBX header for about 4000miles now, and I have the same noise. It sounds like an exhaust leak or spark knock, but it's from the header. I think it's leakage past the flex joint, or the rings in the flex joint rattling around. Since I know it's there I don't let it bother me too much.
Old Aug 3, 2004 | 08:34 PM
andeh22's Avatar
Default Re: header's making fluttering noise (MC_HondaRacing)
wont cause any engine damage?
if this is the problem, am i actually losing power than gaining?
hmongshaa
Honda Civic (2001 - 2005)
20
Apr 22, 2007 03:16 PM
M15
Sep 15, 2005 05:06 AM
CircuitFG
Jan 20, 2005 12:24 AM
WeSsCyDeR
Mar 10, 2003 03:48 PM
B18Redline
Apr 1, 2002 05:00 AM
