haze on inside of front windsheild
Old Jul 6, 2004 | 11:11 AM
staticrex's Avatar
Default haze on inside of front windsheild
Every three days about when I go out in the morning to work, there is a haze crap on my front windshield inside. I don't know what it is but I have tried cleaning the windsheild with alcohal, windex, simply green, goo gone. and still every three days this haze comes back.
I don't know how to explain, but it is hard to see if I leave it on, i can run my finger down and it will leave a line. I have no idea what it is but it won't go away.
Should I clean out the vents, and if so how would I do that? Do I have to take the dashboard out?
Old Jul 6, 2004 | 11:16 AM
AndyD's Avatar
Default Re: haze on inside of front windsheild (staticrex)
Are you talking about condensation on the front windsheild??
Old Jul 6, 2004 | 11:31 AM
Jagan'92's Avatar
Well is it dirt? Do you smoke? Keep the windows open? And do you run the air up the windshield all the time or what?
Old Jul 6, 2004 | 11:53 AM
91Hawk's Avatar
Have you lost any coolant? Could be a small leak in the heater core.
Old Jul 6, 2004 | 12:01 PM
94vtecmn's Avatar
Default Re: haze on inside of front windsheild (91Hawk)
I agree with 91hawk, seen this before on other vehicles as well.
Old Jul 6, 2004 | 12:46 PM
staticrex's Avatar
Default Re: haze on inside of front windsheild (94vtecmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about condensation on the front windsheild??</TD></TR></TABLE>
No its not condensation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan’92 &raquo;</TD></TR><TR><TD CLASS="quote">Well is it dirt? Do you smoke? Keep the windows open? And do you run the air up the windshield all the time or what?</TD></TR></TABLE>
I wiped it with a paper towel and nothing gets on the towel, I do not smoke, don't know if previous owner did, but didn't smell like it when I bought it. I sometimes do drive with the windows down. Run the air up the windshield you mean the defroster? No I don't , don't need it here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91Hawk &raquo;</TD></TR><TR><TD CLASS="quote">Have you lost any coolant? Could be a small leak in the heater core.</TD></TR></TABLE>
I have checked and do check the fluid regularly as being in Vegas if just slightly low could cause for overheating very eazy. And no I have no visible leaks and have not added any fluid since I flushed it.
I don't know how to explain it its just a haze, you can see if from outside the car as well, sometimes it looks like a couple different colors.
Old Jul 6, 2004 | 12:50 PM
Jagan'92's Avatar
AH! you mean different colors like almost oily?? I wonder if there's some sort of rain-x type stuff on it. You need a stronger glass cleaner!
Old Jul 6, 2004 | 12:52 PM
staticrex's Avatar
Default Re: haze on inside of front windsheild (Jagan'92)
Thats also what I was wondering, because if I rub it clean it kind of sometimes smears and won't come off clear. Do you know what would clean that stuff off if it is rain-x? or the sort.
Old Jul 6, 2004 | 01:12 PM
94vtecmn's Avatar
Maybe your A/C is leaking??? That could cause a film......Just throwing out ideas.
Old Jul 6, 2004 | 01:22 PM
3.504's Avatar
i think its an oily junk on there too. stronger cleaner. acetone works great. a laquor thinner will work also, aircraft stripper would probably work well too. just dont get any of that stuff on your skin or interior, it'll mess some stuff up. also dont use a towel that you care about cause it'll bleach out. oh yeah, dont do this in a closed garage or with the windows up in the car, make sure theres plenty of ventilation. prepared to get sick if you smell this stuff for 15 minutes strait.
Old Jul 6, 2004 | 01:26 PM
staticrex's Avatar
Well wouldn't I get like a strong headache if my a/c was leaking? I will try some of those cleaners. None of them will mess up the glass correct? I will put some old towels down on the dashboard so just in case it drips. Thanks for all the help.
Mike
Old Jul 6, 2004 | 03:13 PM
LudeyKrus's Avatar
Mine's done that too. I think it's from your breath or sweat or something; it gets a film on the inside of the window, and it SUCKS when it starts to fog up!
I've heard vinegar works, as well as newspaper. I haven't tried either.
Do NOT use aircraft stripper or anything else like that on your glass! It has a very thin anti-shatter film on it that stripper will eat off!
Old Jul 6, 2004 | 03:21 PM
staticrex's Avatar
Default Re: (LudeyKrus)
Thanks for the info ludeykrus, don't want to strip that off I will try the newspaper and or vinegar.
Old Jul 6, 2004 | 03:55 PM
Slipknt777's Avatar
Default Re: (staticrex)
Coke or Pepsi works to clean build ups and films of sorts...the acids clean just about anything....make sure you get the cola off tho cause it'll get sticky lol
Old Jul 6, 2004 | 04:02 PM
fishdude's Avatar
Default Re: (Slipknt777)
rain-x makes a aint fog that u put on the inside of the window try that
Old Jul 6, 2004 | 09:25 PM
5thGenBen's Avatar
Default Re: (fishdude)
i would use the vinegar to try and get it off and then after that try putting some shaving cream on the inside window. i know it sounds crazy but it keeps the windows from fogging up in the winter in ND and might work in your case as well.
Good luck
Old Jul 6, 2004 | 09:47 PM
alias 33's Avatar
I second the shaving cream, and you can use shampoo too, its and old trick that worked on hockey helmets.
Old Jul 6, 2004 | 10:45 PM
staticrex's Avatar
Default Re: (alias 33)
I already cleaned them with the vinegar so I will see if in a few days it comes back if so I will try the shampoo, and or shaving cream.
Thanks alot.
budget
Jun 29, 2005 07:31 PM
full Circling
Jan 29, 2005 10:23 PM
EM1_GIL
21
Jan 29, 2005 07:42 AM
Fly1865
Aug 28, 2004 09:44 AM
NiiS
Jun 14, 2003 02:03 PM
