h22a slow as hell
i ahve an accord aerodeck with h22a swap in it and with aut tranny from f22. but that thing is slow. i got something like 11 sec 0-60 mi. and vtec is working (i hear how sound is changing) but i have no changes in acceleration. what can be wrong?
Modified by digihippie at 10:59 AM 3/31/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d »</TD></TR><TR><TD CLASS="quote">
my thoughts exactly..
maybe you should:
-look up the gear ratios of your F22 tranny and compare them with an H22 tranny
-take into account that you loose oodles of power from the tq converter. (yes, oodles)
</TD></TR></TABLE>my thoughts exactly..
maybe you should:
my ignition timing is set right at shop. but now i think about cam timing. may be belt skiped a tooth... if belt skip one tooth will i get driveable car that will lack of power at top end? or it will be not driveable at all?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digihippie »</TD></TR><TR><TD CLASS="quote">my ignition timing is set right at shop. but now i think about cam timing. may be belt skiped a tooth... if belt skip one tooth will i get driveable car that will lack of power at top end? </TD></TR></TABLE>
YES! thats your friggin problem, slipping one tooth can change your cam timing a **** tone, that would be your problem, that and the fact your runing it thru an auto tranny, get atleast a 5speed m2f4
it'll run one tooth off with stock clearences, but it'll run like *** when vtec hits. I would definitly check out the cam timing, that's a hard thing to match up but it's critical
thanks. tomorrow i will check cam timing and try to fix it if it will e wrong.
for a vtec sound - it's defenatly vtec, cos for now IABs are connected just to manifold with vacum line (without any control and so on) and vtec crossover i hear exactly at 5500 rpms
today checked the cam timing. it's ok.. i dont know what to do.... =/
it's happened after i've installed drag gen3 turbo kit on that engine. and if i remove blowoff valve and give air to leave intake before throttle body i checked 0-60 mph. 11 sec.. that's slow.
and i defenatly didnt getting something from vtec
same happened with my prelude 96 i was losing from CRx he is 170 ATW and he has b16 and i had doubt that my car is getting slow and my friends said that i messed up my Vtec now i turbocharged it with Garret T-25 BB turbo and the turbo is not tuned yet to show the real performacne i will tune it now the boost is 7 to 8 psi
Help doGG
Help doGG
j00 n33d T3h NAWWWWWWS!!!!!!111!!!on!!e!!!!1
Seriously though, the problem is the tranny that you have your H22 mated to. If there was really anything wrong internaly with the engine or anything like that, then you most likely would not be hitting Vtec, or even be able to rev past about 6k without the ecu giving you **** for it. And if your timing was off if would probably randomly stall and idle like ****.
Oh, and its in a gay Accord
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Nick M »</TD></TR><TR><TD CLASS="quote">an accord f22 auto an h22a? jesus
where does 2nd gear end? 100mph? LOL</TD></TR></TABLE>
Ha.. no wonder it doesn't run right..
so no one can help?
there is an accord with the same swap. h22a+f22 ato tranny. and vtec kicks more powerfull there.
i checked compression on engine and got 260-262-250-262. it's a little high..
i checked everything and engine still doesnt run right
your losing power through the auto transmission like 20 people told you that...what esle do you wanna know that the auto tranny is magically goin to make your vtec kick in harder...auto tranny=poo cheeks.
I wont go as far as its cause you have the f22 tranny cause people with h22+f22 tranny manual run decent times...but lose the automatic man.
on the H22 5 speed
