h22 help
Old Apr 26, 2002 | 12:33 PM
vteclude's Avatar
Default h22 help
how many wires do you have total for the vtec to work?? i had a 92 si and swapped it for a h22. i need to know if there is more than the one wirefor vtec from the solenoid. thanx
Old Apr 26, 2002 | 03:46 PM
PsionixILLusion's Avatar
Default Re: h22 help (vteclude)
I haven't done this swap yet so i'm not totally sure as to what you need to do, however i do know there is more than just 1 wire. Have a look here http://www.hondaprelude.com/resources/article.asp?id=58
and have a look at what this guy did. This appears to be the best resource so far for this swap that I have found. Best of luck to ya and I hope you get it working.
Ever since I drove a 94 GSR, I feel the need, the need for VTEC!!!
Old Apr 26, 2002 | 08:56 PM
kevie88's Avatar
Default Re: h22 help (PsionixILLusion)
There's 2 wires on the vtec pressure switch (one is negative ground) and one for the vtec solenoid.
[Modified by kevie88, 7:40 AM 4/27/2002]
Old Apr 27, 2002 | 06:41 AM
Finest's Avatar
Default Re: h22 help (kevie88)
Don't forget the knock sensor!
Old Apr 27, 2002 | 09:18 AM
kevie88's Avatar
Default Re: h22 help (Prelude_RCR)
And the intake air bypass solenoid!
Old Apr 27, 2002 | 01:47 PM
vteclude's Avatar
thanx peeps
dre23
Nov 13, 2005 12:35 PM
Sabbotage
Aug 2, 2004 08:51 PM
tuan...
Oct 31, 2003 06:19 AM
