grinding in 3rd question??
Old Jun 28, 2004 | 12:04 PM
Inextricabledrvr's Avatar
Default grinding in 3rd question??
i wanted to ask all of you guys what kind of problem this could be..
When i am driving my 5th gen lude normally into 3rd it shifts fine, but when i am shifting fast it makes a grinding noise...i have tested it both ways when i am shifting fast and slow...
it sometimes also does it when the RPMS are around 7K when i am 2nd and going into 3rd theres the grinding noise??
what could be causing this?
Old Jun 28, 2004 | 12:08 PM
01 LudeDude's Avatar
Default Re: grinding in 3rd question?? (Inextricabledrvr)
I'm no tranny expert, but I'd guess your 3rd gear syncro is on it's way out.
Old Jun 28, 2004 | 12:12 PM
chucksnee's Avatar
Do a quick fluid change, mine would grind in 2nd and 3rd.
Quick fluid change and problem solved! Maybe it will work for you?
Old Jun 28, 2004 | 12:29 PM
Default Re: grinding in 3rd question?? (chucksnee)
tranny flush?
Old Jun 28, 2004 | 05:58 PM
Speedra500's Avatar
bad synchros take more time to mesh, putting alot of force into your shifting is bad for your transmission and you should try shifting with a different style and try changing your tranny fluid
Old Jul 5, 2004 | 05:59 PM
95 acclude's Avatar
i agree i believe it is the synchros same thing happened to me but in 2nd
bboyfreeze
Mar 26, 2007 06:41 AM
Ls InTeGrA RaCeR
Mar 7, 2005 04:34 PM
bluels-t
Dec 13, 2004 12:37 PM
elevatethis
41
Nov 24, 2003 12:02 AM
Young_R
Dec 13, 2002 06:30 PM
