gear problem
Hello,
On my 98 prelude, sometimes when i put the clutch in and put it in first, it only goes in half way. It is not fully in gear and i am pressing on the clutch fully. I was wondering if this is a normal problem becuase i recently grind on reverse and this problem occur more often (like once or twice every two days) When this happen i do one of two things to get it in to gear. I shift to second then back to first or i let off the clutch a little while pressing it in to first and then it will just pop right in.
I sort of have that problem? Sometimes mine does not go into 1st properly, it seems to get stuck. Also I can only get into first when car is fully stopped basically, if not I sort of have to push it into first. But I am not sure how to solve it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shrirag »</TD></TR><TR><TD CLASS="quote">I sort of have that problem? Sometimes mine does not go into 1st properly, it seems to get stuck. Also I can only get into first when car is fully stopped basically, if not I sort of have to push it into first. But I am not sure how to solve it.</TD></TR></TABLE>
This is normal, our car wont let us put it in to first gear if we are above 10 MPH. If it's under 10 or a full stop then it will go in to first gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote">It's something inherent to these trans'. If that happens, let the clutch pedal out, then back. </TD></TR></TABLE>
So what your saying is that this is normal with the H22A4 tranny?
My car also make a funny sound when you fold the clutch and give it some gas, once the rpm start dropping, i heard this sound. (sounds like something is rattling around the exhaust pipe)
