fuel on the floor
Old Oct 8, 2006 | 08:05 PM
nonvteclude's Avatar
Default fuel on the floor
ok this was really weird to me. i started my car after it was sitting for a day. backed it out of the garage and saw a big puddle on the ground. i smelt it and it was gas. so naturally a run back to the car and shut it off. i checked all the lines and nothing. so then turn the ignition on accessory, nothing. so i start the car and still nothing, no leaks at all. so now im really confused, i hadn't messed with the fuel lines at all. the last thing i did was put on a new alt belt but drove right after with no problems. has anyone else had this issue before, thanks for any help
Old Oct 8, 2006 | 08:38 PM
99LudeDude's Avatar
your tank may be leaking at a certain point (usually at the seam in the middle) This happened on my crx. There is no leak until you fill the tank above 1/2 and then.......trouble. Try adiing a little gas at a time (in your driveway, not at the gas station, unless you want your car towed.) untill you see a leak. If it leaks after adding gas to the tank, you'll need to repair or replace the tank.
Old Oct 8, 2006 | 08:42 PM
Default Re: (99LudeDude)
i filled the tank 2 days ago with no leak then, im only down an 1/8th a tank from full. gas looked like it trickled down from the firewall and it was on the exhuast. there was none from the tank area
Old Oct 9, 2006 | 01:30 AM
darkspector2.0's Avatar
check your fuel filter..
Old Oct 9, 2006 | 02:18 AM
Revi's Avatar
Default Re: (darkspector2.0)
If the leak is at the rear of the car, inspect the tank. If its inbetween the tank and the front of the doors, inspect the fuel lines undeneath your car. If its at the fron of the car, ispect fuel filter connections, injectors, fuel rail and fuel pressure regulator.
Old Oct 9, 2006 | 05:40 AM
Duane_in_Japan's Avatar
Default Re: (Revi-Ra)
its called wicking, like an old kerosene lantern, the kerosene wicks (soaks) up the wick and burns in the open air. You fuel injector (s) are wicking through their wireing to the computer, open up the ECM and smell for gas. The fuel may have dripped off before it got to the ECM into the floor, goog luck.
If so, you will need to replace all your injectors, OH DAMN, didnt even look, is this a fuel injected model.......................
Old Oct 9, 2006 | 06:25 AM
Default Re: (Duane_in_Japan)
the leak was from the front. there was nothing on the filter, injectors, regulator, rail, or any of the lines. i know what you thinking "it had to have come from somewhere" and thats what is boggling my mind there was no visual place that it was coming from. and today its not doing it at all. could it be that something was holding fuel and by some freak chance when i started it, it shot fuel on the floor? or something like that.
Old Oct 9, 2006 | 01:43 PM
Default Re: (nonvteclude)
ARE YOU TALKING ABOUT THE FLOOR OF THE CAR OR OF THE GARAGE.
Old Oct 9, 2006 | 01:46 PM
ninja 6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">ARE YOU TALKING ABOUT THE FLOOR OF THE CAR OR OF THE GARAGE.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">ok this was really weird to me. i started my car after it was sitting for a day. backed it out of the garage and saw a big puddle on the ground. i smelt it and it was gas. </TD></TR></TABLE>
Old Oct 9, 2006 | 01:53 PM
ninja 6's Avatar
Default Re: (fish stick)
to the op: did you remember letting someone drive your car or hitting a bump in the road...you may have damaged your fuel hard lines...there may be a hole down there in the pipe thats leaking fuel....thats the only logical explanation i can think of...that or you have some kind of fuel gremlin in your car...eating up them lines yo...
Old Oct 9, 2006 | 02:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fish stick &raquo;</TD></TR><TR><TD CLASS="quote">to the op: did you remember letting someone drive your car or hitting a bump in the road...you may have damaged your fuel hard lines...there may be a hole down there in the pipe thats leaking fuel....thats the only logical explanation i can think of...that or you have some kind of fuel gremlin in your car...eating up them lines yo...</TD></TR></TABLE>
no i dont let anyone drive my car and dont remember any bumps. but the weirdest thing is that its not doing it now, only did it that one time. i dont know maybe god got pissed at me for something i did and thought he would scare me.
Old Oct 12, 2006 | 08:23 PM
99LudeDude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">its called wicking, like an old kerosene lantern, the kerosene wicks (soaks) up the wick and burns in the open air. You fuel injector (s) are wicking through their wireing to the computer, open up the ECM and smell for gas. The fuel may have dripped off before it got to the ECM into the floor, goog luck.
If so, you will need to replace all your injectors, OH DAMN, didnt even look, is this a fuel injected model.......................</TD></TR></TABLE>
WTF?!?!?!
I'm pretty sure that fuel cannot flow through the engine wiring harness into the ECU. Call me crazy, but I don't think that is possible. I'm gonna raise the flag on that one.
Old Oct 12, 2006 | 08:29 PM
CGags13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99LudeDude &raquo;</TD></TR><TR><TD CLASS="quote">WTF?!?!?!
I'm pretty sure that fuel cannot flow through the engine wiring harness into the ECU. Call me crazy, but I don't think that is possible. I'm gonna raise the flag on that one.</TD></TR></TABLE>
word...i read that and thought i mustve ate some fungus
Old Oct 12, 2006 | 11:14 PM
redtop22's Avatar
Default Re: fuel on the floor (nonvteclude)
how long was the car sitting around for?
if it was parked for while most of the gas should have evaporated by the time you started her back up again.
maybe it wasn't from your car?
but just to make sure i'd take a closer look at your fuel filter,
Old Oct 15, 2006 | 05:08 AM
Default Re: fuel on the floor (redtop22)
You can raise the flag if you like my friend but dont bet the farm on it, where do you think I got the name 'wicking' from. I didnt say that it happened on a Honda but it is a possibility on some ECMs or I would not have said it, I will admit that I thought he was talking about the floor of the car, not the garage. How else would fuel get on the floor of the car if not down the wire harness.
Wicking is real but maybe not on this car, I concede to that. Saturns are famous for wicking into the ECT sensor connector and wire, I think maybe the wicking issue first popped up on a GM but I would not swear to it.
Bowl_of_Rice
Feb 27, 2011 06:27 AM
bmg123
Jul 22, 2009 07:29 PM
TealCivic93
Apr 8, 2006 09:31 AM
omg_miiiike
Apr 27, 2005 09:27 AM
96turboteg
Jul 28, 2004 11:00 AM
