FLYWHEELS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace_cr »</TD></TR><TR><TD CLASS="quote">Whats the weight of an h22a1 flywheel and whats the average aftermarket compared to that?
Planning to modify the stock one, need some guidelines.</TD></TR></TABLE>
Dunno about stock, but the avg. aftermarket is about 8lbs, usually it's aluminum.
IIRC The stock one is 19lbs.
Aftermarket you can get them in different weights. The most comon weights are 12 and 8. But you can find them in all different weights. Or you can have some weight shaved off the stock one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro »</TD></TR><TR><TD CLASS="quote">IIRC The stock one is 19lbs.
Aftermarket you can get them in different weights. The most comon weights are 12 and 8. But you can find them in all different weights. Or you can have some weight shaved off the stock one. </TD></TR></TABLE>
I thought it was 20....but it sould be right around that weight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by es_squared »</TD></TR><TR><TD CLASS="quote">plus aftermarket ones will spool up faster right? cuz of the lighterness? </TD></TR></TABLE>
yes but you will also drop rpm's faster,
i just had my stock one lightened to about 13-14 lbs
I got the Jun 12 lb chromoly flywheel after my tuner told me the aluminum flywheel on their race civic warped. I guess extreme condintions can warp the aluminum flywheels. Be careful.
