Fitment Question
Old May 15, 2003 | 05:20 PM
SpeedGyrl's Avatar
Default Fitament Question
Does anyone know if a crank pulley from a 93 Lude Si will fit a 99 Base model Lude? Thanks in advance!
Old May 15, 2003 | 09:29 PM
SpeedGyrl's Avatar
Default Re: Fitament Question (99LudeGyrl)
I can't believe out off all the members on here, no one can give me any insight in this.
Old May 15, 2003 | 10:50 PM
JG Luder's Avatar
I'm going to say yes, and then risk being wrong afterwards.
My advice:
Tomorrow morning call Honda and ask them about part numbers for both. If they match, then I'd say they're the same. If they're different, then I'd worry.
*shrug*
Old May 16, 2003 | 08:51 AM
SpeedGyrl's Avatar
Default Re: Fitament Question (Lone Luder)
I found out this morning that as long it is from a V-tec Prelude, 4th or 5th gen, the crank pulley will be the same.
Old May 16, 2003 | 10:32 AM
JG Luder's Avatar
I could've told you that. LOL... the H22A1's, H22A's, and the H22A4's, share everything identically on that side of the block. In fact, aside from being open deck and OBDII with the dist., I don't think there is anything different about it period.
What you're looking at is from an H23A1. It's a non-vtec.
Old May 16, 2003 | 11:46 AM
CHK4TIX's Avatar
when my engine was deliver the pulley was screwed up so i used the pulley off my h23 because i was re-using the power steering and alternator. The only difference is the vtec pulley has 5 splines on the belt and the si only has 4. So I just have to use the si belt instead of the vtec belt and mine works fine.
EHGray
Sep 25, 2008 08:54 AM
thehatchninja
Jul 13, 2008 10:04 PM
celltoolz
Mar 29, 2008 10:38 PM
jfingers
Jun 21, 2004 10:57 PM
93eg-EKhybrid
Sep 15, 2002 03:20 AM
