final drive gear
Old Jun 9, 2009 | 10:11 AM
fraserboostedh22's Avatar
Default final drive gear
hey guys, does anyone knows the difference between oem and after market final drive gear? whats the ratio on OEM? thks in adv.
Old Jun 9, 2009 | 10:17 AM
jnv255's Avatar
Default Re: final drive gear
4.2 is oem.
Old Jun 9, 2009 | 10:21 AM
NirVTEC's Avatar
Originally Posted by jnv255
4.2 is oem.
4.26 and MFactory makes a 4.64 and 5.15 IIRC and you may find some 4.71s out there. Can't remember who made them though. Houseman maybe?
Old Jun 9, 2009 | 10:49 AM
PirateMcFred's Avatar
www.circuitworx.com makes a 4.7FD
Old Jun 9, 2009 | 11:18 AM
thks so much guys! i dont know anything about the tranny. dont mind me asking, so the bigger the ratio the better? what do they do or how do they help with power? I m boosting 7 psi with stock internal and tranny. Please reply, need to know before trying to build. THKS MUCH!!!
Old Jun 9, 2009 | 11:43 AM
jlude90's Avatar
http://www.teammfactory.com/gearcalculator.php
input your ratios and your final drive/tire size and see how your speed per gear changes
Old Jun 9, 2009 | 11:47 AM
Kronn 98SH's Avatar
4.266, actually. Which rounds to 4.27.
Old Jun 9, 2009 | 11:59 AM
92civlude's Avatar
Not sure, but dont you want a taller gear for turbo? 4.06 is the Accord fd. Or H23 trans 4.26 fd has wider intermediate ratios. Would these options be better for turbo? I know Team MF sells a 4.0 fd for b series specifically for turbo applications.
Old Jun 9, 2009 | 01:16 PM
Kronn 98SH's Avatar
OP, Since you're boosted, you want a lower # or at least taller gears. Lots of boosted Luders go with the H23 tranny. Here's the complete list you will want to research.
https://honda-tech.com/forums/honda-prelude-4/prelude-h-series-transmission-codes-ratios-master-list-2548441/
Old Jun 9, 2009 | 02:03 PM
thks. someone on the forum tells me about shorter gear, thats why i wanna ask again. my car has power but not that fast. so maybe i thought i could mess with the tranny to make it faster. Any suggestions? very appreciated.
Old Jun 9, 2009 | 02:04 PM
https://honda-tech.com/forums/showthread.php?t=2548441
thks. it help alot!
Old Jun 9, 2009 | 02:06 PM
NirVTEC's Avatar
The difference between the H22 and H23 isn't noticeable by most......I have driven with 4 different H series trans.....Can barely tell except for 2-3mph here and there.
Now F22/F23......thats a different story!.....My friends H22 with F22 trans didn't hit VTEC in 2nd till 50mph. Sucked.....
Old Jun 9, 2009 | 02:07 PM
it that all i have to do to the tranny? taller gears, would it makes a big difference? thks
Old Jun 9, 2009 | 02:27 PM
can u guys tell me where to find taller gear. Can't find them @ ebay. thks again.
Old Jun 9, 2009 | 02:31 PM
street_ride14's Avatar
I bet that was NA. It shouldn't suck if his car was boosted.
Old Jun 9, 2009 | 03:01 PM
NirVTEC's Avatar
N/A making barely 170whp
Nitrous making 215whp
Still sucked both ways.......
Old Jun 9, 2009 | 03:28 PM
92civlude's Avatar
My previous powerplant was a blacktop H22 with a GUDE PERFORMANCE head and a 97 Accord trans. The car is lightened, 80 mph in 2nd gear! It was sick. Especially on the freeway. Nothing could touch me on the freeway. Im considering dropping my Euro-R trans in place of an F trans.
Old Jun 9, 2009 | 04:11 PM
should i change my tranny to a f series, which one? my car is 01.thks
Old Jun 9, 2009 | 04:21 PM
92civlude's Avatar
Well, N/A in a heavier Lude, Its not going to impress you. If you boost it, you will probably prefer the f22 trans with the taller 4.06 fd. Try it out. F22 trannies are plentiful and low priced. 94-97 Accord 5spd will bolt right up.
Old Jun 9, 2009 | 04:24 PM
NirVTEC's Avatar
But what happened on the street from a dead stop? Nothing.......
Old Jun 9, 2009 | 05:07 PM
92civlude's Avatar
Naw man! It would light it up from a stop. The car is a lightweight 92 EG. Most of the street races I actually got into were from a roll anyway. Around 35 mph, too fast for the competition to start in 1st, too slow for 2nd. This was pretty much where my car came alive! Yeah 1/4 mile was off 1.1 seconds from my setup now. Although, now, Im running a Red Top Euro-R, better suspension, and its tuned. But the trap speeds are actually pretty close.
Old Jun 9, 2009 | 05:13 PM
sorry for too much questions! would those fit directly or some alternation?
Old Jun 9, 2009 | 06:58 PM
MFactory's Avatar
The only reason to go for a longer final gear is to achieve a higher top speed in each gear. Boost != Longer Gears
You car will accelerate faster (if you have the traction) on a shorter geared transmission. Play around with the gear calculator and determine what max. speeds are acceptable to you.
Tip: Don't gear your tranny to hit 170mph when all you will ever do is 120mph
Old Jun 9, 2009 | 07:13 PM
92civlude's Avatar
94-97 Accord 5spd will bolt right in. With no problems. Good hint from MFactory- H23 trans is a good bet too. Kronn 98SH suggested H23 trans as well.
Last edited by 92civlude; Jun 9, 2009 at 07:24 PM. Reason: Credit Kudos to Kronn 98SH
Old Jun 10, 2009 | 08:05 AM
su8854's Avatar
how much does a final drive cost?
