f22b dohc
Old Jan 15, 2009 | 07:35 PM
b20c's Avatar
Default f22b dohc
im runnin a f22b dohc in my 93 si lude on the h23 tranny and ecu. Is the h23 ecu pretty close or will i need to tune it later on?
Old Jan 16, 2009 | 04:15 AM
MoonScryer's Avatar
Default Re: f22b dohc
Its close enough that you won't notice the difference from NOT having the p39 (f22b dohc ecu). In the choice of tuning - anything runs better and has more power once tuned properly.
Old Jan 16, 2009 | 04:46 AM
preluderemis's Avatar
ran the exact same setup as u for a while...and to answer your question the h23 an f22 are almost identical in evry way so no u wont notice the difference as mentioned...btw did u wire a knock sensor on your f22???
Old Jan 16, 2009 | 07:54 PM
b20c's Avatar
not yet thats my only cel.
Old Jan 22, 2009 | 06:41 AM
just wire in the knock sensor and shift at 6500 roughly...beleive me...i blew my old dohc f22 beating it till i could se the connecting rods from outside the car
Old Jan 22, 2009 | 07:03 AM
PirateMcFred's Avatar
Obviously tuning is going to make any engine better, but as was stated before you'll be fine in the meantime.
I suggest getting some cams for that engine. If you're going to tune the engine you might as well have a bonafide reason to do so. They're cheap and you'll have a reason to rev higher than 5500 rpm too.
Pirate
DelsoldS
Jul 3, 2010 03:25 PM
not-a-stang
Mar 4, 2009 11:33 PM
slowe6
Apr 2, 2004 06:12 PM
teamlegacy
May 15, 2003 10:18 AM
DLB1994
Jan 7, 2003 07:46 AM
