f22 head work
Trying to find out what a good step up valve or valve's would be good without spending a lot of money, also need springs, circle track car running6-7k tons for 25-35 minutes a session
Nope, Supertech doesn't make anything for the F22's. I called them to see if they did cause i'm in the process of building mine. The two i found were Bisimoto and KMS Engine Development they both make valves, guides, springs, and retainers for the F22A. I went with Bisi's cause he offers a 2mm over 1mm over option where as KMS only overs .5mm over on both
I can only run a mild cam due to "stock" regulations, competition is running a non stock cam but we came prove without causing a big **** storm, we can only run a non vtec single cam in this class what kind of cam would be a good recommendation for this motor withour bringing a lot of attention
I talked to Delta abt regrinds for my h23, seems they are more popular in accord forums, ie f22. BTW they have several cam profiles, i think 252, 262, 272 or some such numbering. Give them a call, they regrind about anything and have made cams for old engines from scratch when needed.
GL
Mike
GL
Mike
