Engine running lean!
Old Mar 10, 2010 | 10:11 PM
Tunerguy1989's Avatar
Default Engine running lean!
I checked my spark plugs and they are covered in white residue. So this means my engine is running very hot (lean). Is there an easy fix for this or the only way to fix it is to get a tune. Could lost performance from my injectors be part of the issue. I have a cold air intake installed and NGK platinum spark plugs. Any input would be appreciated.
1998 Prelude SH
Old Mar 10, 2010 | 10:28 PM
Kronn 98SH's Avatar
Default Re: Engine running lean!
Probably a clog or malfunction in the fuel delivery.
Old Mar 10, 2010 | 10:42 PM
Ya maybe, Ill probably call RC injectors to have them clean and restore my injectors thanks for the input.
Old Mar 10, 2010 | 10:45 PM
Kronn 98SH's Avatar
Is that cheaper than simply replacing them?
Old Mar 10, 2010 | 11:03 PM
I haven't checked their prices yet but I think so unless I was going to buy used injectors and what would be the point of that because they could have their on issues.
Old Mar 11, 2010 | 11:32 AM
BB1 H22A LUDE's Avatar
Thought I would throw these two out there as well, have you changed the fuel filter recently? Also, I have seen a couple of H22A's that had malfunctioning fuel pressure regulators. They still worked but just at the bottom end of the allowable fuel pressure readings, which caused the engine to run lean. May thus be good to check your fuel pressure, would rule out these two, leaving only the injectors.
B18ceed
Apr 27, 2006 06:09 PM
chechin
Sep 1, 2005 09:28 AM
91integraLSVTEC
Nov 16, 2003 08:38 AM
Stubbs
Nov 1, 2003 05:35 AM
Stubbs
Aug 19, 2003 01:06 PM
