Engine Rebuild question help please
Old Apr 3, 2003 | 08:11 AM
ludesleep's Avatar
Default Engine Rebuild question help please
Did you guys ever replace the main bearing cap bolts when you did your rebuild? Is in nessasary? If so ARP the way to go on them as well?
Old Apr 3, 2003 | 07:35 PM
ludesleep's Avatar
Default Re: Engine Rebuild question help please (ludesleep)
Old Apr 3, 2003 | 08:46 PM
93ludeSi's Avatar
I think ARP makes a whole kit for an engine rebuild, and the stuff they make is good. Hey whats the deal on the H23 block, I am interested, racerX_333@yahoo.com if you want to email me
Old Apr 4, 2003 | 09:19 AM
flyrod's Avatar
I reused the stock ones, no problems. If you are planning boost new stock bolts might be good. ARP is nice, but probably not really necessary. If you are planning freequent tear-downs, ARP is definitely the way to go.
Old Apr 4, 2003 | 07:45 PM
93ludeSi's Avatar
Default Re: Engine Rebuild question help please (flyrod)
be careful when reusing stock head bolts, the are designed to strech when torqued, where as the ARP bolts do not
Old Apr 4, 2003 | 08:07 PM
ludesleep's Avatar
Default Re: Engine Rebuild question help please (93ludeSi)
THATS what im thinking thank you! Im just gonna go ahead and get new ones from arp fuckit better safer than sorry
Old Apr 10, 2003 | 01:14 PM
RuffRhyno's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ludeSi &raquo;</TD></TR><TR><TD CLASS="quote">be careful when reusing stock head bolts, the are designed to strech when torqued, where as the ARP bolts do not</TD></TR></TABLE>
Hhhmm I have a question. I know that Honda bolts are made as a "one time use only type deal", they stretch when torqued down. What I didn't know was that ARP bolts aren't made this way... So they can be reused?
Does this also apply to ARP's headbolts? So I can reuse them?
Old Apr 10, 2003 | 01:47 PM
93ludeSi's Avatar
Default Re: Engine Rebuild question help please (RuffRhyno)
the arp bolts do not stretch, so you can reuse them, Actually they are studs that you torque into the block then slide the head over them, you then use nuts to hold the head down. So they are reusable, but if you are pushing a big turbo its always good to go new everytime, just to be safe.
Honda Power
Aug 21, 2006 12:19 AM
1PT-SICK
Apr 15, 2006 03:22 PM
wildoutwhitegsr
18
Feb 17, 2006 07:09 AM
stackz
Feb 23, 2005 03:59 PM
boosted3g
Nov 21, 2001 04:45 PM
