ECU wiring
Old Sep 22, 2002 | 02:16 PM
a1-bb1's Avatar
Default ECU wiring
Ok, I'm going to install an autometer dual pillar gaugepod with a/f meter and fuel pres. I don't have a helms manual so bear with me as I try to figure out a good wiring plan... First of all, these are the pinouts for a vafc install, but it's got all the connections I'm going to need i think.
Anyways, to get 12v switched to the gauges, is the part on the pinout labeled 'signal power' what i'm looking for? Where should I grab my power from?
Should I run ground wire all the way to the ecu or is it ok to ground it somewhere on the driver's side under the dash? And I'm assuming its ok to splice the power/grounds together by the pillar and just run one wire for each to the ecu, but I dont really know, so any input on this would help a lot. Thanks!
Old Sep 22, 2002 | 06:39 PM
BoostedH23a1's Avatar
Default Re: ECU wiring (a1-bb1)
i just ran mine to the white wire comming off the 4 wire O2 sensor not off the ecu.
Old Sep 22, 2002 | 07:43 PM
a1-bb1's Avatar
Default Re: ECU wiring (BoostedH23a1)
sorry, i dont know what you mean
Old Sep 23, 2002 | 01:12 AM
fastludeh22's Avatar
for 12v, run to any 12v switch sorce, i used the radio connection. the white wire on the o2 sensor is the signal wire for the a/f ratio
civictildeath
Mar 17, 2005 12:27 PM
4gzchatch
Sep 15, 2004 06:41 AM
Sketch_hs
Aug 19, 2004 08:44 AM
StupidSlowRSX
May 11, 2004 06:11 PM
A11MotorR
May 22, 2002 12:22 PM
