ECU code 1... O2 sensor... what is wrong?
Old Jul 11, 2009 | 06:26 AM
zarbel's Avatar
Default ECU code 1... O2 sensor... what is wrong?
Hello,
i've test a lot of thing, and always this f*** error code 1
i've change the lambda and it was same thing
i've change fuel filter and then fuel pump
look at injector and spark...
see the timming belt
but always the code 1!!!
what is wrong?
i've read this http://wikitest.pgmfi.org/twiki/bin/...y/OxygenSensor
and i understand the o2 sensor is on / off position?
please help
Old Jul 11, 2009 | 07:22 AM
Pullig's Avatar
Default Re: ECU code 1... O2 sensor... what is wrong?
code 1 is faulty ecu get another ecu and see what happens
Old Jul 11, 2009 | 08:39 AM
zarbel's Avatar
code 1 is O2 sensor not the ecu
Kronn 98SH's Avatar
Code 1 is for O2 sensor. Follow all appropriate troubleshooting outlined in Chapter 11 of the Helm's manual.
Old Jul 12, 2009 | 09:44 AM
zarbel's Avatar
i don't've the honda scan tool
i've make a lot of test today...
replace fuel pressure regulator, change the lambda (civic one), and many small replace (map sensor air temperature sensor)
same ****!
when i disconnect the lambada i've code 41
but all the time i've the ****ing code 1
i'll test continuity soon... if anybody 've a idea...
lambada are different beetween civic and prelude lambda? where i can buy a lambda for my lude (same as the origin) without the price of Honda sales
Old Jul 12, 2009 | 11:26 AM
Kronn 98SH's Avatar
What are you referring to when you say lambda?
Old Jul 12, 2009 | 11:51 AM
bluedlude's Avatar
lambda sensor = O2 sensor
Old Jul 12, 2009 | 12:58 PM
zarbel's Avatar
yes thanks
Old Jul 12, 2009 | 09:16 PM
Kronn 98SH's Avatar
Originally Posted by zarbel
where i can buy an O2 sensor for my lude (same as the original) without the price of Honda sales
www.sparkplugs.com or www.ebay.com.
However, your O2 sensor wiring (not the plug) might be bad, or possibly your ECU.
Old Jul 12, 2009 | 09:49 PM
zarbel's Avatar
thanks
wiring look good, i'll go with a p28 and eCtune soon but i don't understand, i'll look at voltage on Lambda quickly
Old Jul 13, 2009 | 04:45 AM
zarbel's Avatar
the o2 sensor is specific on honda prelude? or a O2 from a civic VTI is okay?
Old Jul 13, 2009 | 06:47 AM
Targa250R's Avatar
be professional
What engine is in your Prelude? What is the current ECU part number? What year is the Civic VTi, and which engine does it have? VTi trim can have either a SOHC VTEC or a DOHC VTEC engine depending on the model year and country.
Most OBD-1 primary oxygen sensors are the same, but not all of them.
Old Jul 15, 2009 | 10:59 AM
zarbel's Avatar
i've an H22a8 obd2 from a euro 5G in a 4G
i've test my old 4g lambda, a OBX prelude o2 sensor (for prelude vti) actualy i've one 02 from an D16z6 sohc vtec...
the ref in my oem lambda are
OHC 501-h3
NTK : Japan
8G31
it's a 4 wire obd2
thanks to help me
Old Jul 15, 2009 | 01:24 PM
Targa250R's Avatar
be professional
Are you running the OBD-2 ECU?
Old Jul 15, 2009 | 06:45 PM
zarbel's Avatar
yes!
Old Jan 2, 2010 | 04:11 PM
hondaprofessor's Avatar
i got the same problem on my obd1 95 gsr, i tried another ecu and same thing, im using a chipped p28 with o2 disabled and still get code 1, i unplugged o2 sensor and same thing
AccordEX1991
Aug 6, 2007 02:49 PM
tossnupweight
Dec 2, 2003 08:44 AM
