Door Lock Replacement?
Old Dec 15, 2008 | 08:03 AM
Whaty's Avatar
Default Door Lock Replacement?
yea i own a 1982 honda prelude, and recently became very cold here and the door lock actually broke and i now have the piece the key goes into..... my question is how bad is it? where can i get parts to fix it? and about how much will it cost?
Old Dec 15, 2008 | 12:27 PM
turnofftheradio's Avatar
that shouldn't be too difficult to fix. You will need to replace the whole core, hopefully they are still available... If not, as I remember there is a guy in WA or OR that is parting out a 1st gen on thisoldhonda.org. I have got a few parts off him, good guy to deal with. the fix should be easy for a locksmith, providing you can still get a core.
Is that plastic? I've only seen aluminum ones.
http://www.thisoldhonda.org/ads_detail.php?ID=972
Old Dec 15, 2008 | 02:06 PM
Whaty's Avatar
yea its plastic, and i went to your link it took me to a guy named Rich whos located in Knoxville TN. what if i buy the door handle and just replace that? wouldnt that end up working or no?
Old Dec 15, 2008 | 02:21 PM
dcypher6425's Avatar
I just replaced my lock cylinder on a 94. if you do buy the whole handle take it too the locksmith before installing. they will still have to remove the cylinder from the handle part, however most of the work is done for them. for them to re-key my cylinder was less then $10.
Old Dec 15, 2008 | 02:24 PM
teefunk01's Avatar
yep locksmith can do it for fraction of what you would pay to buy from dealer
Old Dec 15, 2008 | 02:31 PM
whoops. Washington, Tennessee.... anyways, if you cannot locate a locksmith that has a core, you could easily swap the handle and lock assy, then have it re-keyed inexpensively.
Old Dec 15, 2008 | 02:54 PM
Whaty's Avatar
i found a place that has some preludes 80-83 (interchange able ones) and he says if i pull the handle its 35 bucks... how much to have it rekeyed?
Old Dec 15, 2008 | 07:11 PM
Crash_Control's Avatar
Take your key with you. You might get lucky and find one that matches your current key.
Old Dec 15, 2008 | 10:01 PM
slamdlude's Avatar
IF you find a lock cylinder just take the tumblers out of your old lock cylinder and put them in the "new" lock cylinder. if you want detailed instructions just pm me, I'm a locksmith.
CRXnTX
Nov 2, 2023 09:42 AM
RobbyFisher
Jan 23, 2014 11:44 AM
jeremyrocksursox
Mar 5, 2009 04:49 PM
vtec8804
Jul 21, 2007 12:51 PM
tinkertime
Jun 14, 2006 04:56 PM
