did compression test half compression on every cylinder
Old Dec 19, 2006 | 03:06 PM
dreamreaperx's Avatar
Default did compression test half compression on every cylinder
what would cause this problem?
Old Dec 20, 2006 | 09:22 AM
godslayer's Avatar
Default Re: did compression test half compression on every cylinder (dreamreaperx)
Pour a teaspoon of oil (motor, not olive) into a cylinder and then crank to test compression. If your compression goes up (from your original test) you likely have bad rings and if nothing changes then it's likely time for a valve adjustment. This isnt a promise of whats wrong but it helps point you in the right direction.
That little trick saved me a lot of teardown time on many 4-cycle engines.
Old Dec 20, 2006 | 02:01 PM
Default Re: did compression test half compression on every cylinder (godslayer)
thanx appreciate the input...ill try that and see how it goes
Brandon Peters
Oct 18, 2015 05:37 PM
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
Uncle Ben's
Dec 8, 2007 12:21 PM
greenli0n25
Jan 26, 2004 07:29 AM
